Idk if the slight increase in turbo time is worth the weight tbh
ok, accepted. sorry, i forgot that 6061-T6 density is 2.7 g/cm³ but not 3.4 g/cm³. i.e. you will have about + 25-37% work time in high power mode.
what is the price? where to purchase ?
I think the price is 44-46$US with a coupon, from Banggood.
Request PM for 44$US price to member freeme
Dang. Too bad the optic won’t work with LH351d.
iam blind or late-the copper version is already made?thanks…
Alu+Cu version will be available in a few weeks time.
that’s a bummer, no true moonlight then
Banggood have some cheap 2XShockli IMR 26650 3.7V 5500mah on offer!!!
I edited it for comprehension, sorry.
Banggood have some cheap? Shockli IMR 26650 3.7V 5500mah?
If your in the US, here’s a reputable distributor Shockli 26650 IMR 5500mAh
I’ll be ordering mine from there. All they have is flat top but it appears thats what’s used with this light.
JasonWW:
Ryzbor:
How many AMC’s does the driver have? I assume it’s the triple channel type.
We have not seen any info about the driver yet.
The MF01S is a 2 channel driver using a resistor bank controlled by a small FET (due to being 6 volt) for the first 500 lumen, then switches to the bigger FET.
This light can use 7135 regulators (due to being 3 volt) so the design might be 2 ch or 3 ch.
We don’t know yet.Update, it’s 3 channel.If anyone sees any pictures, please let us know. I’m guessing Lexel designed it, I’ll ask him.
What? Why would you think this? Of course it has a true moonlight.
The SST-20 4000k is mile better in terms of color reproduction and tint, but suffers in efficiency due to the 95CRI rating.
[quote=JasonWW What? Why would you think this? Of course it has a true moonlight.[/quote]
Read now it has a triple channel driver, another advantage over the FF E07.
The Alu with copper head model looks fantastic
Convinced. Since it uses the supposedly nice/acceptable tinted FA3 tint I hope swapping three leds to supposedly slightly rosy 2700K SST-20’s will result in neutral tinted soft warm ~3500K light.
But does it have the manual mode memory feature?
Just make sure you match the Vf of the different colour temp LED’s. I also had that in mind seeing that I have a few 2700K JA3 with VH Vf bin.
Does anyone know the Vf bin of the 4000K SST-20’s in the MF01 Mini?
I just preordered one in black, 4000K.
Looks like a very nice light.
Best battery for this light that wil not fry the leds?
I cancel the preorder and go for Mateminco MT07 with XPL-HI 5000K.
Has there been any word about when these will ship?
There is no battery that will fry the LEDs, so you are safe there.
There is no “best” battery. I say this all the time. What are you looking for? The highest output to measure? If so, you can use a Samsung 30T very high drain cell, but only 3000mah.
Do you want the highest capacity even though it’s not the brightest? One of the PLB 5500mah based cells is a good choice.
See my earlier post and search the thread since we have talked a lot about batteries already.
