They don’t write the colors but it’s the third option from below ‘custom colors note color’. You would need to contact them, ask what they still have and order with this option then. There are no pictures from the seller just customer reviews.
Oh I see. Thanks for the tips. I’ll see how much I like the light when I receive mine. If it is good, I might by one of those special colors. I really like my purple MF01S. I might buy a purple or pink MT07 for my daughter if the quality is good like the MF01s.
I've just seen this by ToyKeeper "Since this light uses SST-20 emitters, the tint varies from green-ish to pink-ish as the power level changes. Lower levels are more green, higher levels are more pink." So that explains the green tinge I'm seeing which goes as I up the powah.
I've tweaked the pots on the Aux LED's. excuse the crappy phone shots:
I know, it's apples to oranges, that's why I stated which batteries I was using, my point was the fact that the Mini requires two double-clicks from off to hit turbo, the D4S doesn't (and doesn't take a 21700) and I wasn't aware of that fact.
Yeah, the mini uses Anduril. From off, a double click goes to top of the ramp and then you do another double click to get Turbo. If the light is on, a double click will go to Turbo. This is one of the small quirks that I don’t like.
The D4S uses RampingIOS. I don’t think it makes a difference whether the light is on or off, a double click will always go to the highest output.
I can’t believe this is still still listed as a “con” for Anduril lights, just set your “ramp ceiling” to 1 click and you have full turbo from on or off with a single double click.
I can only say this is my opinion. I don’t know about anybody else. I also prefer instant on and off and a triple click always being battery check. What can I say, I’m more of a narsil kind of guy.
Are you able to take power consumption (current) measurements for the aux-LED? I’m wondering how high the “parasitic drain” of the aux-LEDs would be when at max brightness.
