Wow, GREAT REPLY, friend!! Worked perfectly. I used my phone to flash at 40Hz, then ramped the light back and forth until the flash from my phone became a solid white light when the FW3A shone on it.
I'll try it again on my comp to make sure the flash rate is set correctly. But it all was amazingly simple.
I actually just went to the website MWS referenced in his post. The settings on the website are very intuitive, and I just set it up to flash my phone's display between black and white at 40Hz. Then,played with the Disco Mode flashing speed until the display on my phone appeared constant (in my case it was white).
It's an amazingly simple solution, I love those types of fixes! :)
The 40Hz comes from a study that showed in mice with Alzheimer's disease, the 40Hz flashing light helped "reverse" temporarily some of the major effects. There's a podcast about it somewhere out there, I'm hoping Google will turn it up.
So, trying some preventative maintenance on the ol' noggin here ;)
not sure how helpful online strobes are, but at least can give an idea what you are hoping to seeā¦though I find watching two strobes at the same time a poor way to achieve accuracy.
It would be better to have something spinning at some measured speed and strobe thatā¦like a fan bladeā¦
Searching for an app to measure strobe hzā¦something that might measure hz if you flashed it into the cameraā¦
Thatās interesting. Im going to look into it but PM me if find any additional info. I am beginning to show signs myself plus suffer from CTE. :weary:
If I may, I think it more a case of, this high-precision-build light doesn't lend itself easily to mass production, especially if the goal of production is quantity over quality/good QC.
It seems like the problems we are seeing are mostly the results of assembly errors on the part of the manufacturer.
Iām having an issue where the light flickers like crazy. Itās like it gains and loses 10% of its brightness a few times a second. It also takes almost a full second to turn off after hitting the button. Has anyone seen any issues like this?
I ordered glow gaskets from Neal on May 22nd paid for expedited shipping and order is still shows unfulfilled. Nothing from Neal, have several projects that are at a standstill waiting to get finished.
