Anduril has a turn off delay, this is normal. It looks for another button press before turning off.
As far as flickers, this sounds odd. There might be a dirty connection somewhere. I’d suggest cleaning the threads and making sure the driver retaining ring is tight. You know, the usual stuff we’ve been suggesting.
Ok, interesting problem. My light will go into and out of lockout unless it has been in lockout for a few hours. Then the light will not unlock with 4 quick press, I have to loosen the head to unlock it. Has this been seen, am I doing something wrong?
Carried this and used this light for almost a month with no problems . Then suddenly would not work right . Ramp up only part way and turn off. Thought battery needed charged , but that wasn’t it . Read Firelight 2 , post # 30 . The driver retaining ring was loose . Works fine again . Thankyou Firelight2 .
Last night was my first time carrying my FW3A and its already broken…
The light turned on in my pocket and I didn’t notice until I felt the heat. After turning the light off, it appears the lower regulated modes do not work.
If I turn on the light and hold to ramp up, it turns on in brighter modes only.
I can’t tell what my floor/ceiling/thermal/battery settings are at because the blinks use these lower modes.
Switching to stepped ramp mode seems to make the light go dimmer than smooth ramp will allow it to go - but I only have ~7 discrete steps (all on the high-brightness end).
I suspect one or several of the 7135’s are damaged. Any troubleshooting suggestions I should try before requesting a new driver?
I too have had this failure mode, only once, up to pressing I didn’t pay it much heed at the time and it’s not recurred since; I keep the torch in 4 click lockout mode most of the time, unlocking if I need more than ML mode. A week or so ago, I couldn’t get the torch to unlock with any number of clicks and had to resort to taking the head off and rebooting it.
No, it sounds like you’re probably right. Not much can cause those symptoms except for a dead 7135 chip.
I wonder if it was having a switch contact issue. If the switch was constantly flapping on and off, or if it sensed multiple presses per click, it would be difficult or impossible to unlock.
Once in a while I see it detect the wrong number of clicks, but not very often and not to an unusable extent. Usually if it happens it’ll just get two for one. This can happen because the switch on the FW3A is pretty noisy electrically, and can take a while to settle to a steady state. The only switch I’ve tried which was more bouncy was a cheap crappy switch people use in lightsabers.
Meanwhile, the switch used in the Emisar products is unusually clean. Back when the D4 was the only supported light, I used completely different code to read the button presses… because the switch sends a really clean and solid signal. But when I started adding support for other lights, I had to make the button code tolerate noise. In the case of the FW3A, it had to deal with quite a bit of noise.
So if it refuses to unlock, as a way of testing for this, I’d suggest trying to loosen the head just a little, tighten the tail, and gently tighten the head again. Ideally without causing the light to reboot, if possible. This should take care of any switch contact issues and help determine whether that was the problem or if it was something else.
If switch contact was the issue I would think that it would also rear it’s head with other multiple click operations. So if changing to/from ramping, battery check, etc work with no issues then perhaps it’s something else. I would also vary the click speed when unlocking it to see if that makes a difference.
Yes, it should affect other things too. But it sounds like the issue only happened once, and was resolved by removing / reattaching the head. So that leaves a lot of possibilities open. I’m hoping more data can be collected to narrow down the theories of what happened.
