With light turned On, click 4 times to enter ramp config mode. At the prompts (fluttering light), respectively, click 1 time, then 21 times. If there is a 3rd prompt, click 7 times (this is seen when in stepped ramping mode).
Ok, I give up, no more time to search. When in lockout both of my FW3A’s first click to moonlight and second click to a mode higher than moonlight. My buddy at work just got his and when his is locked out the first click gives something brighter than moonlight and second click gives moonlight. How did he manage to reverse these and how do I tell him to fix it?
I thought I read somewhere that if you disconnect power, hold the tail button and connect power again it would factory reset. Is that even possible with the FW3A and electronic switch? Or was that just for lights with mechanical buttons that run Aduril?
First, Anduril doesn’t work with mechanical switches at all. What you describe works for newest Anduril versions of regular e-switch lights (currently only the newest D4v2’s, not the first batch). Since FW3A doesn’t really allow you mechanical lockout there is an alternate reset method (I think it’s 13 clicks and hold from off) but again that would not be on an FW3A yet unless you flash it yourself.
What Jason describes is only how to get the ramp top and bottom back to default. He shouldn’t call that a reset.
Because there is now an actual function called factory reset and it does a lot more. This resets just one setting. I imagine before too many more FW3A runs they will probably have the true “factory reset” but your steps will still be useful if you dont want to lose all your other settings.
Besides, people almost never accidentally change the temperature settings. It’s always the ramp levels. Probably because it’s so easy to accidentally get to. The temperature settings are harder to access by accident. I don’t think we even need the factory reset that ToyKeeper added. It might be better to change the way we access the ramp level adjustments. 4 clicks while on seems too easy. I think most folks either keep it stock or else try a few adjustments and then leave it.
