just got my lights today as well. My AW 2600 protected flat tops fit with a 1.5mm magnet on top. they measure 68.5mm with magnet. they are flush with top of tube. this is not including the height of the three bumps on negative end. they do not interfere with spring tip or cap so I did not include them in the height measurement. I also used a digital caliper to measure from the center of the driver to the back edge of tube and come up with 68.26mm so i think 68.5mm battery is max that will fit. cap screwed completely down with that setup
I tried 3 batteries. The AW’s above, a Panasonic NCR18650GA, and some samsung ICR18650-26c pullouts. The Panasonic GA pulled the most current. Max with my meter and long leads was 2.5amp with the GA. Around 2.40amps with the Samsungs and AW’s. Not sure if these numbers are close to being accurate as I am just using an old meter with long skinny leads.
I got both 3c and 1A bins. Both are really nice. I like the 3c most as most of my other lights are around the 1A color. I am supposed to get 3 pcs 5a but may pass on these as I really don’t see going warmer than the 3c which is already very natural looking.
Mike
