Sorry for delay reply, we will set a coupon today or late for tomorrow, we are waiting for the contrast video for the 3W and 10W, once it was done, we will share with you. Thanks.
Gearbest, I want to buy one of each bulb, but I can only apply one coupon code to an order, so I have to make separate orders. This is extra work for you guys to manage multiple orders instead of just one. Is there any way to fix this?
Also, thanks for all the great support you’re providing on BLF. You are moving up my list of preferred vendors.
Thanks for your notice and support to our store, but I’m sorry that we can’t change the order system after communicating with our technical staffs, could you please order for one of each time? Sorry for this inconvenience, hope you can understand.Thanks.
I got mine today. Just note when you get it and proceed to try out the remote functions, the remote needs to be pretty close to the bulb for it to work. I tried it in a desk lamp and thought I had a bad remote because it didn’t seem to be working, took the battery out of the remote and checked it with dmm, good battery. Finally, I decided to try it really close to the bulb and it worked. My remote only had an effect within 15 inches from the bulb.
It starts on red light when first powered. Then it cycles through each of the colors. There are four functions on the remote; flash, strobe, fade, smooth. They don’t really do what they’re labeled as far as I can tell. Flash just cycles through all the colors (1 second on each color before changing to another color) . Strobe seems to do the same as flash, but it stays on the color a little longer before cycling to the next color (ie. slower version of flash - 3 seconds on each color). Fade cycles through the colors, but it fades from one color to the next. Not sure about smooth mode, it’s like the fade mode.
Pretty cool for a few bucks. I only got the 3W version. I think it’s about as bright as a night light. I’ll have to wait until dark to really see how bright it is.
Oh, forgot to add that it took 41 days from order to delivery!
are you sure you are pointing the remote at the bulb? mine (from another vendor) it seems to be pretty sensitive to line of sight, but works from >4m away
the pwm is marginally better than an older rgb i have, but still visible
Yes, pointing directly at the bulb. Only works from within about 15 inches. Maybe I got a dud?
What about the modes? Is strobe mode like strobe mode in a flashlight? This is my first light bulb of this kind, so I’m not really sure how is suppose to work. I didn’t see any instruction pamphlet with it either. It just came with the remote and bulb (in a box).
