:+1: MOLICEL/NPE INR-18650-P26A - CUTTING EDGE “POWER” CELL.
Preliminary testing of the Moli P26A shows performance better than the VTC5A, which was the best high power 18650 battery before. This exceptional 18650 cell is designed to deliver continuous 35 amps for the most demanding applications.
EXCLUSIVE MOLICEL/NPE AUTHORIZED US DISTRIBUTOR - GUARANTEED TO BE GRADE A, UNUSED, AND MANUFACTURER APPROVED.
Liion Wholesale is the sole authorized US distributor of these cells in partnership with New Power Energy. Other versions sold as “OEM” are not officially authorized sales and are not direct from the factory. Unlike unauthorized “OEM” P26A, these are guaranteed genuine, grade A, and in unused.
The cells BOD[Born on Date] are September 19,2018,3.5 months old! :+1:
Molicel isn’t a no-name brand. Infact I’ve just sent about 2 dozen to the recycle bin from laptop pack pulls (not these specific molicels) while in then process of reducing the number of unused cells I store in my home. Nothing was wrong with them I just have better low drain / lower capacity options to keep and use.
We just have to wait & see if they stay good , the vtc6 is good when new but it’s life expectancy goes down with age. How do you think these will age ? Perhaps wolfdog can retest after extensive use.
That is true,I will definitely retest them down the road. I am anal about cycle life, voltages and run times. I keep track of that with ALL of my batteries.
Hopefully these have decent longevity. They will be in my TN42vn90. 5000L/1Mcd.That light demands good High Drains!
If the capacity test is done before 6 pm I will post the results before I hit the trail,if not when I get back.
NOT absolutely confirmed but MOST likely the APEXIUM INR 18650 2600mAh is a Molicel P26 RE WRAP.
HKJ tested BOTH the Apexium and your Vapcell 18650 2600 25A. EVERY Amp setting was basically identical on his comparator. When HKJ gets MOLICEL OEM P26A at end of January[test in February] that will be more evidence,although Not 100% without further testing by the experts!
