Thank you for your active participation. The list of winners we got through the random.org website is as follows:
1,#4 Ledhead
2,#76 sesgum
Congratulations! Please PM us to send your recipient information including name, address, phone number, etc. We will send the prize as soon as possible.
Thank you, everyone. Have a nice day!
The lightweight headlamp Cyansky HS3R is coming. Small size, lightweight, red and white dual output, all-metal design, magnetic tail, ECO mode, max runtime of 60 hours, wider and more comfortable headband. Is it the headlamp you want?
Features:
1* white LED, 2 * red LEDs.
7 modes Output by one-switch Control.
White and Red Light Dual Output.
Powered by 1 * 16340 battery and compatible with 1*CR123A.
Full Metal design.
Type-C rechargeable.
Magnetic tail design.
Max. 1100 Lumens and 200 Meters.
Max. runtime 60 hours.
Compact and Lightweight(55g with battery).
Wide and comfortable headband.
5-lumen ECO mode.
Waterproof: IPX8(2 meters underwater)
Impact Resistance: 2 meters
Working Temperature: –30℃ ~ 50℃ / –22℉ ~ 122℉ Product link
Click on the video to learn more about HS3R Headlamp
【Giveaways】What do you think of this headlamp? Leave your comments here and we will randomly draw 2 lucky winners to win Cyansky HS3R headlamps on August 31st. Good luck!
This looks outstandingly versatile, covering close-up work or illuminating the whole work space (or path). I look forward to seeing what the dimmest setting is on the red LED output.
I like that it has red, but I don’t know about the headband. I do quite a bit of after-dark running and I’ve never used a hard plastic headlamp holder that was half as comfortable as a silicone holder.
Cool white. NO WAY.
Press and hold for on. NO
Press and hold for off. NO.
Only one solid red level.
No clip.
Too much of a visible hot spot. I don’t really see anything that I like about it.
