Group Buy-BLF X6-SE OP update-GB over.
Maybe. But its been gone for over a week now.
The problem is not one of these manufacturers or sellers give me the confidence to know exactly what I’m buying and where from.
I could start up Eaglesfeet flashlights from our WC and no one would know. That’s the internet for you I guess.
Marc.
Thats kind of the point, your buying from who knows where, eagle eyes today comes from one factory, tomorrow one at the other end of china, companies don’t have history or reputations and corporate headquarters, they don’t work the way we think of corporations in the first world
They deliberately obscure everything possible, for plausible denaibility, for governmental reasons, to obscure chain of custody (especially when supplying first world companies) and so on.
A few more observations and updates.
Since getting my NW X6 SE I’ve had chance to use it a few times now. On MAX it never gets warm when outside, not even close.
The step down is also vastly more noticeable than I’d have thought it would be too. Ok you might not notice the instance it steps down, but you do realise the spill is dimmer and you can no longer see as far.
On MAX the X6 will light up the trees on the far side of the park, once stepped down it doesn’t. Out walking this is quite a noticeable drop. The real bummer is then the UI, you can’t just bump it back up to MAX again without going through all the modes. :frowning:
Generally I’m a huge fan of auto step downs to regulate heat (works brilliantly on my EagleTac). But is completely redundant on the X6.
My 2nd example is a CW one, I added wire to the springs and it did bump amp draw, although visually wasn’t such a big jump. Anyhow, this one sat on the shelf for a few weeks, when I picked it up to use it again it had turned into single mode somehow. Can’t see anything shorting or wrong it. Don’t know if it steps down or not as I didn’t run it long enough.
Anyhow I pulled the stock driver and used a blank 17mm board and have no converted this one to direct drive. Using a Samsung 25R it is significantly brighter than my stock NW one. It also heats up now. Obviously no lower output modes with this setup, but fine for my intended use.
That interesting, what amp does it pull when DD on the 25R?
Will check tonight. But it is a heck of a lot brighter, I did a ceiling bounce lux test, can’t recall exact numbers but from something like 440 lux stock to 620 lux direct drive.
Thanks i am very curious what it will be, we have seen so many different amp reading from different drivers, set ups and batterys on this light but never a DD one.
What do you think of the possibly of using a Quantum Tunneling Composite to make it in to a big twisty?
http://www.ebay.com/itm/QTC-Pills-Quantum-Tunneling-Composite-pills-DIY-inf-variable-brightness-3-/381008511441?pt=US_Flashlights&hash=item58b5e081d1
Well lets get honest here eagle eyes is making a light that is exactly like a convoy S2+.
and simon gets a red convoy s2+ in and is excited that he got a SAMPLE .... Minos has a nitecorn name and slaps it on an ennora? Ignorra ? firecorn ?? and says branding doesn't mean squat ..
Does anyone really think there are a bunch of companies in china with english names ?
If we had any sense we'd stop making BLF special edition lights ...instead we should have created a brand . 5 years later our lights would be nice enough to be putting serious pressure on the big boys ..Mr.Efin would be effin scared .
on a side note ..i hate this driver .. the spacing is pure unusable crap
nice light... stupid poorly thought out driver
sorry cabfrank .. the truth will set you free :P
This is the reason I bought a standard X6. At least then I can change the driver. I just don’t Trust some one in china enough to do it for me.
What’s more I have probably got a real eagle eye x6 and all the blf X6 were clones. Who knows?
Marc.
I am hoping when I get a soldering iron someday that a qlite driver goes in with no problems and the retaining ring does not get in the way
but in fact apparently three on the order page:
How many variations of these things did they make, again?
Is one of them “neutral”?
EDIT — according to BLF back in 2012 “A T6 4C doesn’t exist. If you want a 4C tint, you’d need to go to a T5 bin. Well, that’s what Cree says on their data sheets….” but others said, well, eventually it might exist.
Are we there yet? Apparently IntlOutdoor sells them on Noctigons now
You really need a single sided driver. The retaining ring does not like 7135’s on the back of a Qlite.
BLF17DD fits.
Ordered 2 Eagle Eye blf edition from the GB on 09Dec. Tracking shows nothing except that it has been “excepted” on 19Dec? What’s up?
That is pretty normal. China is slow during Christmas. Once it hits your country it should update.
Thanks
Just tested with a fresh 25R. My DMM reads 3.67amp vs 2.6’ish max on the stock X6.
I’ve been using mine lately. It’s a nice light (seems like it’ll replace my C8 for regular use), but it seems to have only two modes — low, high, high, and high with step-down to high.
The main thing I’d change about the host is to make it tail-stand better… it’s wobbly with a big head and two narrow flat spots on the tail.
After I get some stock measurements, I’ll probably change the lens on my NW model (get rid of the AR coating to improve tint), replace the CW emitter with a de-domed XP-G2 for throw, and maybe replace the drivers in both. But I’ve been lazy and it’s not a priority.
How much does it cost?
I have found the glass not to affect the tint much, in fact i would not know it was there if i had not read this thread and looked carefully at the glass
What is the final group buy tally?
You got it wrong, its: almost moon, low power light high, average power light high, with step up to…wait did it step up? Maybe I should check to see if I pressed it…yep went back down to almost moon so it must have been in turbo, OK cycle it up again…
Still like it though :slight_smile:
Personally the driver is ok with the exception of the mode spacing.
At the very least it has no visible PWM and has off-time memory.
