I plan on reflowing a XM-L2 U2 on a 20mm sinkpad, getting a 3.04A Nanjg and letting her rip…I figure that is a middle of the road muscle car kinda build…
There cant be to many group buys. Not everyone buys a light from every group buy so when the right one comes along we can participate. I'm in for two here the price is that good. Happy wives, do we really worry?
Im at 4,1A with a quite sophisticated Bocian driver in my "moderatly driven light". Also with a nice and rare tint. XM-L2 T5 5A3 80+ CRI. Turned it into a really nice light with great tint and UI.
XM-L2 U2 1A with 5,9A Qlite in my other light. Im not using that light as much as the other one... Just wanted to make a really bright F13. :D
The JingKong 4Ah still $6.75 at Lightmalls. I’ve been delaying buying 26650 but now I have BLF A8, HD2010 and now possibly this F13… maybe nearing time to step up. Panasonic might release 4Ah 18650 this year but the price will probably be 3x this 26650 in the beginning anyway.
We are around 40 pieces now. I think we will hit 50, especially if I have GearBest do a "code" like we did with T-mart. That will spread around to other forums and that will give them over the 50 piece mark. Since there is no high limit, then it should be no problem spreading it around.
I’m probably in for at least 1, but is the driver for this light a 2-board driver? If so, does anyone know what the sizes are for the driver and the contact board?
Also, their website shows they use Paypal. Does the $9. price include PP fee?
In that case, then just a blob of solder should work as well. Just solder across to jump the component, or even solder a wire on. But, the reason for a resistor there is to control the time to reset, is it not?
Correct, if you solder blob it you will likely get stuck in the first mode (hopefully high). Solder blob may also cause other problems such as a high parasitic drain. I’d use a low value resistor (in the thousands of Ohms still) in place of it.
Playing with different high value resistors like discussed in your link (or just playing with the amount of graphite you lay down from the pencil) allows you to control the reset time.
