Hey lads so I made this video its just a first look at the Haikelite MT03 to much talking and a bit of testing and if course some beam shots it’s not the review its just an over view. It should at least give you a run down of the light.
The ceiling bounce test will show you how bright this light is.
Link to buy the light.
HaikeLite MT03 Devourer
Okay i got some pics of what you wanted i am over run with lights to review now.
This is the head of the MT03
My cells do not make proper contact i know its hard to see but the positive terminal is recessed
The MT03 is the first light on the left
The height the MT03 is on the left again.
Specs:
—Emitter: Triple CREE XHP70 N4 CW or N2 NW
—Aluminum Alloy body with HAIII Anodize black surface Finish
—Battery: 4x High Drain >10A Flat Top 18650 (only fit standard flat-top 18650, Single light do not include battery)
—Switch: Side electrical switch with big Transparent rubber boot
—Aluminium OP Reflector
Ultra Clear Double-sided AR coated Glass lens (99% Light transmision )
—Double O rings; IPX8 Waterproof
—With standard Tripod hole
—Max Brightness: 8760 Lumens CW ; 7560 NW 5000K CRI80
—Max Runtime: 58 days
—Brightness Level: (Digital current regulation)
Low Low: 10 Lumens (28 days )
Low: 150 Lumens (35 hrs to 10% power)
Middle: 1000 Lumens ; (550 minutes to 10% power)
High: 2700 Lumens (330 minutes to 10% power)
Hidden moonlight: 0.6 Lumens ; 58 days
Turbo—8760lumens —–2.5 minutes (thermal control) step down to 5500 Lumens—–2 minutes (thermal control) step down again to 2400 Lumens (300 minutes to 10% power)
— Timed Temperature stepdown and thermal regulation
Size: 127mm length x 72mm Head x 50mm body
Weight:600 Gram
UI:
Single Click-on ; Single Click-off
Hidden Moonlight (press and hold switch in off status; easy to access)
Low Low-Low-Mid -High-turbo (Long press to change modes ; with last mode memory)
Quick access to Turbo (Double click in any mode easy to access) ; Turbo can be memorized.
Click+hold+flash signal to lockout the light; Repeat to unlock. Tail cap-lockout also available
Switch LED indicator:
100~50 power: Blue LED on
50~9 power: Blue LED flash twice every 2 seconds
Blow 9% power: The flashlight will flash fast and step-down to moonlight.
The indicator LED will be off on Moonlight mode to extend the run time.
Internal parts:
40mm Haike Copper DTP Emitter board
20 gauge thick copper+silver wires
5mm thick internal integrated emitter shelf
double silver-plating copper-alloy springs
Okay lads another update the review ill be in a few days hold on tight! If you want a mass lumen light this is your best bet. Think of this as being a new S70 or L6 we all know how good the value is on those! Who knows once Haikelite becomes bigger they could raise there prices. Hopefully not we need a company that can give us mass output at a good price right now there is no one.
Driver! Its hard to get a good angle
eh i will flip and zoom in just because i love you!
Driver retaining ring is beastly! It is 5mm in thickness
Other side of the driver retaining ring
The hole in the middle is so you can stick your wiener in there! Technically its meant for the screw that holds the reflector in place! But if it fits it fits!
The screw that hodls the reflector in place is massive this could have also fallen lose from my head hahaha
Bottom of the reflector the base is 12mm in diameter.
Top of the reflector is 25mm if i measured right? looks like i jizzed on it but i think its only a spiderweb from microfiber cloth becauyse its gone now. Total length of the reflector is 60mm
I probably should have measured this but i didn’t think to at the time
The lens is 2mm thick and 67mm wide.
Usually i wouldn’t do this but i had to check it out i would give the MT03 a 10/10 for modifying purposes!
