Another new powerful flashlight from HaikeLite.
MT07S 5000 Lumens , 750meter throw, full current regulation with a lot of nice UI function
Specifications:
Emitter: CREE XHP70.2 NW 4800K
Meterial: Aluminum Alloy , HAIII Anodising
Battery: 4x18650 (Recommend Sanyo 18650 GA 3500mah 18650)
Reflector:SMO Aluminum Reflector
Lens: Double Side AR coating Glass Lens
Bezel: Stainless Steel
Waterproof: IPX8
Max Output: 5000 Lumens
Max runtime: moonlight 1 lumens—60 days
Digital Full Current Regulation
Anti-reverse protection
Anti-discharge protection
Demension: 175mm x 66mm x50mm
Netweight: 470 gram
Accessories: landyard,O rings,Tripod Mounting Screw
Brightness Modes:
Low: 150 Lumens
Medium I: 450 Lumens
Medium II: 1000 Lumens;
High: 2200 Lumens
Hidden Turbo:5000~5500 Lumens (double click at any time)
Double click again:Strobe
Hidden Moonlight:1 ~3 Lumens (In off status A long click for 2 seconds to access moonlight. )
Thermal control Remove / Activation:MT07S comes with thermal control by default. If you want to remove thermal step-down , turn the moonlight mode on first and press the switch for 3 seconds to remove thermal control function. When you see a signal flash, it means the thermal control function has been removed, and MT07S will have no step down any more.
The thermal control function will recover when you cut off the power supply.
User Interface:
single click on; single click off
Long click to change modes ; Double click to Turbo ; Double click again to Strobe ;
With last mode memory
In off status a long click for 2 seconds to access moonlight mode ; another long click for 3 seconds to remove thermal control. Cut off the battery power to recover thermal control.
Lockout Function:
A single click followed by long click to lockout the switch. Repeat to unlock.
Power indication light: (LED indicator under the metal switch button)
100~50 Blue led on
50~9 Blue led flashes
Blow 9% Red led flashes
Camera setting : Shutter- 1.3S ; Aperture F4; IOS 200
MT07S XHP70.2 NW 4800K ; SMO Reflector
MT07S CREE XHP70.2 NW SMO Reflector VS MT07 Buffalo XHP70 CW 6500K OP Reflector
