Find the group buy page here https://budgetlightforum.com/t/-/49135
Finally… it is my pleasure to let everyone see the latest to the Haikelite line the MT09R.
This is the 70.2 emitter version, the 35 high should be arriving soon and I will add it as well as some video of the lights side by side.
Specifications:
Emitter: 3x CREE XHP35 - Hi / 3x CREE XHP70.2
Material: 6061 Aluminum Alloy; HAIII finish
Batteries: 4x 18650
Max Brightness: 7500 lumens on 35hi version / 15000 lumens on cree xhp70.2 version
Brightness mode: Moonlight> Low low>Low > Medium>High>Turbo >Strobe>SOS>Beacon+ Step less Ramping Control
TA Driver , Current regulation on Low Low > Low> Medium>High ;
Size: 169mm length x 74mm x51 mm
Net weight: 550 gram
It felt like it took this one forever to arrive, but it only took 4 days.
When I took it out of the box the first thing I noticed was that it is a bit shorter than the MT07S… 14mm shorter to be more exact.
Other dimensions the top (outside of the bezel) is 73mm, inside the bezel across the optics is 64mm and about 170mm tall
These new models from Haikelite do not have the same driver issues from the past.
Thanks to Texas Ace they all now use a TA style driver and while I have not yet opened it up to have a look I can tell you that not only will it make the 15k lumen promised but above. My last reading was 16297 lumen. Excellent job.
Now on to the distance calculations, I did there twice to be sure and both times I got the same (6 meters difference).
90000 Candela with an est. throwing distance of 600 meters.
Now it is gong to be very hard for me to prove 600 meters but I am betting it will out throw it’s older brother the MT07S. We will see how it comes out in the video.
The weight is good, and the finish is excellent, all the machining is what we have come to expect from Haikelite.
Most of this review will be more for letting everyone see what the light can do so the majority of it will be video.
I am not going to tear down either light until after all the testing and video footage has been taken. I do not have the parts here now to repair anything that could possibly get damaged.
Just FYI at least for this testing I used 30q’s. I honestly forgot to request a set of the Sony’s
I have asked for some to be shipped if possible so that when I get the 35 high we can see if there is a performance difference.
Okay the rest of the fun will be in the video below…. Enjoy
www.youtube.com/embed/6i4V52apyeM
www.youtube.com/embed/78e-eBi488Q
