After long-term’s research&development HaikeLite will release 6 brand new LED flashlights in September and October.
Below is our Triple XHP70 prototype
The light have almost finished the QC test. They are very close to mass production.
Since the light showed in picture is a prototype sample, Some details are not so perfect. You can notice some sharp edges on it and dirty spots on reflector. We will update new final sample pictures next week.
HaikeLite Triple XHP70 MINI Monster
Specifications: (info From the prototype, not the final version)
—Emitter: Triple CREE XHP70 N4 CW or N2 NW
—Aluminum Alloy body with HAIII Anodize black surface Finish
—Battery: 4x 18650 High Drain (65mm to 67mm cell length) ; 2S2P configuration
—Anti-Reverse protection
—Switch: Side electrical switch with big Transparent rubber boot
—Aluminium OP Reflector
—Ultra Clear Double-sided AR coated Glass lens (99% Light transmission )
—Double O rings; IPX8 Waterproof
—With standard Tripod hole
—Max Brightness: 8500~9000 Lumens (Max 10.8A on turbo ; have not done the real test, so it’s Pending )
—Max Runtime: 58 days
—Brightness Level: (Digital current regulation)
Low 0.1A 80lumens; Low:0.5A 400lumens Middle 1A 800 Lumens ; High 3A 2400 Lumens ; Hidden moonlight 0.7mA- 2 Lumens ; Turbo—8500~9000 Lumens
— Timed thermal stepdown and thermal regulation …
Size: 127mm length x 72mm Head x 50mm body
Weight:600 Gram
UI:
Single Click-on ; Single Click-off
Hidden Moonlight (press and hold switch in off status; easy to access)
Low Low-Low-Mid -High-turbo (Long press to change modes ; with last mode memory)
Quick acess to Turbo (Double click in any mode easy to access) ; Turbo can be memorized.
Click+hold+flash signal to lockout the light; Repeat to unlock. Tailcap-lockout also available
Switch LED indicator:
100~50 power: Blue LED on
50~9 power: Blue LED flash twice every 2 seconds
Blow 9% power: The flashlight will flash fast and step-down to moonlight.
Internal parts:
40mm Haike Copper DTP Emitter board
20 gauge thick copper+silver wires
5mm thick internal integrated emitter shelf
Double silver-plating copper-alloy springs
Double Sling Holes ; Enable a camera strap to fit this light.
Final version will be Blue switch-LED.
The left one is HaikeLite XHP70 Thrower
MT03 CW 7000K CRI75
Light up a huge area
Compare with A car High-beams ; MT03 is double brighter than the Car High-beams
Beam in the woods
the dark road at night
MT03 lights up the road
HaikeLite MT07 Buffalo single XHP70 thread link:
