Dr Jones I have been trying from the time I have read the pm you send me to find the lines but with no luck. Two are the possible situations, I am blind or something is wrong with the file I have…
Take a loom please…
I am pasting your luxdrv3.0
// LuxDrv 0.30 DrJones 2011
// 994 bytes with ramping and timer
// License: Free for private and noncommercial use for members of BudgetLightForum
// changes:
// 0.1 first version: levels,strobe,beacon,timer(136) (638bytes)
// 0.2 ramping(200), improved timer(180), skip mode1 as next mode if already in mode 1 (898bytes)
// 0.21 changed EEPROM handling to reduce power-off-while-writing glitches —>eepsave(byte) (874bytes)
// 0.22 bugfix in ramping; mode not stored on (very) short tap (878bytes)
// 0.3 battery monitoring added; step down and indicator in beacon mode (994bytes)
//ToDo:
// ? off-time checking; requires adding diode,R,C
// ? blink your name in morse code
#define outpin 1
#define PWM OCR0B //PWM-value
#define adcpin 2
#define adcchn 1
#define portinit() do{ DDRB=(1<<outpin); PORTB=0xff~~~~(1<<adcpin); }while(0)
#include <avr/pgmspace.h>
#define byte uint8_t
#define word uint16_t
//########################################################################################### MODE/PWM SETUP
//251, 252, 253, 254 are special mode codes handled differently, all other are PWM values
#define F_CPU 4800000 //CPU: 4.8MHz PWM: 9.4kHz ####### use low fuse: 0x75 #######
PROGMEM byte modes={ 0, 6,51,255, 254, 251, 252, 253 }; // with ramping
// dummy main modes ramping, ramped mode, strobe, beacon, timer
#define TIMER 5 //use timer (5 min, max 6 in this setup)
#define RAMPING //use ramping
#define MINPWM 5 //needed for ramping
#define RAMPMODE 4 //the number of the ramping mode (254) in the modes order; e.g. ramping is 4th mode -> 4; not counting dummy
#define LOCKTIME 12 //time in 1/8 s until a mode gets locked. 12/8=1.5s
#define BATTMON 125//enable battery monitoring with this threshold
//PROGMEM byte modes={ 0, 6,51,255, 5,6,14,37,98,255, 251, 252, 253 }; // 9kHz modes, 5 is lowest, no ramping
//// dummy main modes more levels strobe,beacon,timer
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <avr/sleep.h>
#include <avr/eeprom.h>
#define WDTIME 0b01000011 //125ms
#define sleepinit() do{ WDTCR=WDTIME; sei(); MCUCR=(MCUCR &~0b00111000)|0b00100000; }while(0) //WDT-int and Idle-Sleep
#define SLEEP asm volatile (“SLEEP”)
#define pwminit() do{ TCCR0A=0b00100001; TCCR0B=0b00000001; }while(0) //chan A, phasePWM, clk/1 ->2.35kHz@1.2MHz
#define adcinit() do{ ADMUX =0b01100000|adcchn; ADCSRA=0b11000100; }while(0) //ref1.1V, left-adjust, ADC1/PB2; enable, start, clk/16
#define adcread() do{ ADCSRA|=64; while (ADCSRA&64); }while(0)
#define adcresult ADCH
#define ADCoff ADCSRA&=~(1<<7) //ADC off (enable=0);
#define ADCon ADCSRA|=(1<<7) //ADC on
#define ACoff ACSR|=(1<<7) //AC off (disable=1)
#define ACon ACSR&=~(1<<7) //AC on (disable=0)
//_
volatile byte mypwm=0;
volatile byte ticks=0;
volatile byte mode=1;
byte pmode=50;
byte eep[32]; //EEPROM buffer
byte eepos=0;
#ifdef RAMPING
byte ramped=0;
#endif
byte lowbattcounter=0;
void eepsave(byte data) { //central method for writing (with wear leveling)
byte oldpos=eepos;
eepos=(eepos+1)&31; //wear leveling, use next cell
EEARL=eepos; EEDR=data; EECR=32+4; EECR=32+4+2; //WRITE //32:write only (no erase) 4:enable 2:go
while(EECR & 2); //wait for completion
EEARL=oldpos; EECR=16+4; EECR=16+4+2; //ERASE //16:erase only (no write) 4:enable 2:go
inline void getmode(void) { //read current mode from EEPROM and write next mode
eeprom_read_block(&eep, 0, 32); //+44 //read block
while((eep[eepos]==0xff) && (eepos<32)) eepos; //+16 //find mode byte
if (eepos<32) mode=eep[eepos];
else eepos=0; //+6 //not found
byte next=1;
if (mode==1) next=2; //+10
#ifdef RAMPING
if (mode & 0x40) { //RAMPING
ramped=1;
if (mode & 0x80) { next=RAMPMODE+1; mode&=0x7f; } //mode: for savemode
//else next=1
}else //ENDRAMPING
#endif
if (mode & 0x80) { //last on-time was short
mode&=0x7f; if (mode>=sizeof(modes)) mode=1;
next=mode+1; if (next>=sizeof(modes)) next=1;
} //else next=1; //previous mode was locked, this one is yet a short-on, so set to restart from 1st mode.
eepsave(next|0x80); //write next mode, with short-on marker
ISR (WDT_vect) { //WatchDogTimer interrupt
if (ticks<255) ticks;
if (ticks==LOCKTIME) eepsave(mode); //lock mode after 1.5s
#ifdef BATTMON //code to check voltage and ramp down
adcread();
if (adcresult<BATTMON) { if (++lowbattcounter>8) {mypwm=(mypwm>>1)+3;lowbattcounter=0;} }
else lowbattcounter=0;
#endif
int main(void) {
portinit();
sleepinit();
ACoff;
#ifdef BATTMON
adcinit();
#else
ADCoff;
#endif
pwminit();
getmode(); //get current mode number from EEPROM
byte i=0;
#ifdef RAMPING
byte p,j=0,dn=1; //for ramping
if (ramped) { //use the ramped mode
pmode=255; i=30-MINPWM~~; while(i—){pmode=pmode~~(pmode>>3)–1;} //get PWM value //never gives 250…254
} else
#endif
pmode=pgm_read_byte(&modes[mode]); //get actual PWM value (or special mode code)
switch(pmode){
case 251: mypwm=255; while(1){ PWM=mypwm; _delay_ms(20); PWM=0; _delay_ms(60); } break; //strobe 12.5Hz //+48
case 252:
#ifdef BATTMON
adcread(); i=adcresult; while (i>BATTMON) {PWM=8; SLEEP;SLEEP; PWM=0; SLEEP; i-=5;} SLEEP;SLEEP;SLEEP;
#endif
mypwm=255; while(1){ PWM=mypwm; _delay_ms(20); PWM=0; i=70;do{SLEEP;}while(—i); } break; //beacon 10s //+48
#ifdef TIMER
case 253: i=TIMER; do{ //+180
byte j=i; do{PWM=255; _delay_ms(20); PWM=0; _delay_ms(300); }while(—j); //blink remaining minutes
byte k=30; do{ byte m=0; do{ //wait 1 minute
if (m<i) {_delay_ms(233);PWM=8;_delay_ms(90);PWM=0;}
else _delay_ms(333);
}while(++m<6); }while(—k);
}while(—i); //for TIMER min
i=100; do{ PWM=255; _delay_ms(30); PWM=0; _delay_ms(70); }while(—i); //strobe 10s
while(1){PWM^=8;SLEEP;} //”off”
break;
#endif
#ifdef RAMPING
case 254: ticks=100; //crude way to deactivate the 2s-lock //RAMPING
while(EECR & 2); //wait for completion of getmode’s write
while(1){ p=255; i=30-MINPWM-j; while(i—){p=p-(p>>3)–1;} //ramp up
PWM=p;
eepsave(192+j);
SLEEP;
if (dn) {if (j ) j—; else {dn=0;SLEEP;SLEEP;} }
else {if (j<30-MINPWM) j; else {dn=1;SLEEP;SLEEP;} } //wear leveling
} break;
#endif
default: mypwm=pmode; while(1){PWM=mypwm;SLEEP;} //all other: us as PWM value
//mypwm: prepared for being ramped down in WDT on low-batt condition.
}//switch
return 0;
}//main
