Specifications:
◎3* Cree XM-L LED (U2) with a lifespan of 50,000 hours
◎Battery: 3 × 18650
◎204 mm (length) x 52 mm(body width) x106 mm(head diameter)
◎1200-gram weight (excluding batteries)
◎4 levels of brightness: Turbo (3.8A*3)>High(2.2A*3)>Med(0.8A*3)>Lo(0.05A*3);with mode memory
◎Brigh tness:Turbo(3000lumens)>High(2000lumens)>Med(600lu mens)>Lo(80lumens)
◎Digital Current Regulation
◎Capable of standing up securely on a flat surface to serve as a candle
◎Tail cap click Switch
◎Made of durable aircraft-grade aluminum
◎ Super deep Aluminum Alloy Reflector;Shotrange up to 800meters
◎Premium Type III hard-anodized anti-abrasive finish
◎Toughened ultra-clear glass lens with anti-reflective coating
◎With mode memory
X40
Features and Specification:
LED: three Cree XM-L U3 LED with a lifespan of 100000 hrs.
- Infinite brightness magnetic control ring ,minimum brightness : 3 lumen ,fully variable from minimum 3 lumen to maximum 3280 lumens;
Strobe: 3280 lm. 2.5 hrs.
- Working voltage: 4V to 13V.
- Max runtime: 1500 hours.
- Max beam distance: 420 meters.
- Peak beam intensity: 41500cd.
- Impact resistant: 1.2 meters.
- Waterproof to IPX-8 standard, 2M.
- Size: 181.5(L)x 68.00(bezel diameter) unit: mm.
- Weight: 580g without battery.
-Stainless 304 bezel and rotate-ring
-Can charge directly
- Aircraft grade aluminum body structure.
- Premium type III hard anodized anti-abrasive finish.
- Ultra-clear tempered glass lens with anti-reflective coating.
- Momentary forward click tactical switch.
- Strobe mode for tactical and emergency use.
- Smooth reflector for max light output.
- Highly focused beam for maximum distance.
- Tactical knurling for firm grip.
- Streamlined body design.
- Mechanical reversed polarity protection design for battery carrier.
- Intelligent highly efficient circuit board design for max performance
and long run time.
- Specially designed for Military, Law Enforcement, Self-defense, Hunting,
Search & Rescue and Outdoor activities.
- Intelligent temperature controlled light output for user safety
