The “DRY driver” I have, and which I used, is apparently the “old” DRY driver:
It looks like the current/new “DRY driver” that CNQ has has a toroid, instead of the two chips on the top board, and has a 32mm contact board, vs. a 23mm contact board in the older DRY driver (which is what I used).
I don’t have any of the “new” DRY drivers, so I don’t know how it’d work with a single XM-L.
Oh man, since when they enlarge the DRY driver into 32mm? What are they gonna use it for? I thought I already have the newer version of DRY driver ordered in October of last year!
Its also the same as I linked to in OP ("Ebay SST90 driver), which is basically the same as the lustefire triple I have mentioned several times. There might be small variations on these drivers, but they all seem to do pretty much the same. People seem to have measured 7A 7,6A or 9A based on what I can remember (not sure if 9A were output though).
INPUT current. The input will vary with the input voltage/number of cells to get the same output. They don't mention the output, which is the part that matters.
I just did some testing on my HX-1175B with an XM-L2 and 2 Samsung 20R's. It started at 7.05 amps, then fell to 6.78 and stayed there.(I think there is a little too much resistance in my skinny leads) I let it on for about a minute. Driver was coolish to the touch. If only I could get rid of the strobe and SOS, I think this would be a nice driver. It's going into my upcoming CuHD2010 build. I was also hoping to resistor mod this driver to get it to 8 amps, but the SMD resistors that I bought at Tadaya are way too small.
Thanks. What values have you stacked on top and what amps did you get?
I did a little more runtime testing, mostly to see how hot it got. It didn't get hot. The hottest temp I recorded over several minutes was 120F right on the MOSFET surface.
Sorry RaceR86 for the wrong driver you got but i orderd one from that seller and it arrived today and it is HX1175B not HX1175C maybe he sent you a wrong one Sad
i have tried it on MT-G2 with 2 cells it gave me 3.6 A with 3 cells it gave me 6.9A so what i can do to raise it to 9A ? should i try 4 cells or resistor mod it ?
I just bought two of these...http://www.ebay.com/itm/Direct-drive-high-driver-circuit-board-for-Cree-XML-XM-L2-SSCP7-SST-90-LED-/171244724523?&_trksid=p2056016.l4276
Direct Drive...Med...Low ...Strobe and SOS Meh for strobe and SOS, but I like the direct drive.
I'm going the route of Tivo's Z8 based East-092 DIY driver -- Best of Both worlds - direct drive and regulated lower modes. Hopefully will get one working in the next few days.
