Modes: moon (~0.25 lumens), low (~5 lumens), med (~30 lm), high (100+ lm)… I don’t really care much about dual AA+14500 support, but if it allows both the modes should be the same output with either battery type (with an extra turbo mode added on 14500).
Memory: none, or at least, has an easy way to access moon from off no matter what state it was in before
A Nichia 219B with a floody TIR optic sounds awesome. Or perhaps a reflector with a frosted lens. High-CRI neutral-to-daylight white with a smooth, floody beam.
It’d be awesome if the body could be bare brass or stainless steel. A screw-on clip would be nice too (don’t care if it’s reversible as long as it can work in a bezel-down deep carry fashion). Hopefully small overall, like a L3 L10 or D25A.
Ideally, it would be a twisty, or a twisty with a button so that either one could be used (Thrunite T10S for example). Or an e-switch, since that offers lots of interesting UI options.
Constant-current output is ideal, but fast PWM (~18000 Hz) is okay too.
Moddable is good. Ideally, I’d love to be able to pull the driver out and reflash the firmware. I like to put a bunch of weird modes on my EDC and otherwise generally mess with the interface.
I’d be willing to help create the firmware, as long as it can be open-source. So far I’ve only done attiny13 firmware, but am open to other MCUs too.
Edit: So, BLF has a pretty lively community for modding 1x18650 lights, with lots of readily-available hosts and parts for building pretty much anything. The Convoy S series is a good example, and anything else which uses the same-sized components. But that doesn’t really happen for 1xAA or 1x14500 lights due to lack of parts. What I’d really like is to have the same degree of mod components available in a 1xAA form factor as what we currently have for 1x18650 lights.
