DT35: 8000 lumens, 1000 m throw
DT70: 16000 lumens, 700 m throw
Which light would you go for? I already have a tm16gt and am wondering which of these I should get next. I would opt for an Acebeam X65 but they are $500(anything similar available for less money?)
Also for both of the Imalent lights, does anyone know approximately how long they stay at the max rated lumens for? Anyone have an output graph?
I am very reserved about the lumen and throw, there are no throw measurements or runtime graphs as of yet. But we sure have lots of hype from the discounters.
FWIW I am considering the DN70, compact flood light. Got one in my Amazon cart… getting ready to pull the trigger.
I can’t tell though if it can unscrew the tailcap or head to terminate battery contact. Mechanical lock out is not a deal breaker but its pretty high on my list of priorities as a backpacker and outdoor user.
I would be shocked if this light is an honest 3800 Lumens. If it is it sure won’t be for long, with a 6V emitter and single 26650.
If both lights do what they’re supposed to do, I’d get both; discount price is great. I’m really worried they are just a piece of junk. One member here told us to stay away from these lights who got the DT35. I believe he’s the same guy (need to double check) who got four HaikeLites and was pleased with them. So HaikeLite was ok, but not the Imalent… Go figure…
Yeah I bought both of them, with DT70 is still in custom somewhere in US, received DT35, first impression it’s a nice compact light,
works only with protected button top :person_facepalming:
No spring in the tail , can only be open from the top, problem is without the bottom spring, some of the batteries is uneven and didn’t make contact, thus causing issues with the turbo mode.
When I finally get it to work, ( for briefly few secs ) it has a nice tight beam but I really doubt the 8000 lumens claim.
I already known they always over rated their lumen claims, but nevertheless they do build nice lights.
I have few of their not so friendly budget lights
Hopefully, DT70 will go over 10000 lumens, at least more than haikelite, which btw can be bought for 3 of them for the price of DT70.But it’s a Christmas gift for myself
I’ll try to post a mini review of DT35 soon along with comparison beam shot with Nitecore TM16GT.
I posted a question somewhere else as well, but is there no compliance at all in the battery tube for the cells? I mean, I understand if you have four cells, it’s likely that one cell is not going to make proper contact. But this means all DT35/70 will have this issue; you must be lucky to have four cells that have really the same length… Sounds like a bad design to me then…
Maybe you want to wait for DT70Vn? btw if you want crazy bright light, there’s a member here is selling TK75 modded by vihn using 4 XHP 70, that’s a real eye scorcher…with Fenix deep reflectors it should throw well too, just don’t expect the runtime will last
Just got the DT70 today, they both are the same dimension and length ( DT70 is 1mm longer) probably just my light…
Unfortunately for m, somebody broke the seal on the box and the batteries were down to 3.12V,and the other 3 is around 3.4V and the manual are missing too, did someone from the custom or DHL play around with this light?
Didn’t really get to try the light yet, as both light are very sensitive regarding the batteries, my sanyo GA won’t wotk, even sanyo GA button top won’t work either.
Tried it with protected panasonic 3400B, it work briefly like maybe 5 secs before it shut down and refused to turn ON again. :person_facepalming:
So… I had to charge the Imallent batteries and maybe I’ll try it again before I go to sleep and compare it with Olight X7.
Well… in theory it supposed to be brighter than Olight X7 or HaikeLite MT03 since they both only have 3 XHP70
Now how am I supposed to figure the mode on this light?
2. For various reasons. The DT70; to add another item to my collection, to share a performance slot with the TK75Vn Quad 70.
The DT35; to add a multiple XHP35 light of its size class to my collection.
The answer to “Why?” for me is because an item does what nothing else in my collection does (such as the X65) or because I am adding another item to my collection to share a niche with items that I already have, because I am interested in that particular niche.
