IN STOCK!: Shadow SL3 & JM26 + Full Line
I’m opening this thread up to discuss the 2 flashlights for now while China is on their national holiday. As soon as they’re back they should be shipped out to us. In the meantime enjoy the pictures
Shadow Flashlights in stock!
Still have the GF1 and 26650s to add but they should all be there
Use “SBHOL” for 10% off!
Lux
JM26: 36k lux on my 2.5A sample. 3.0A production model should be 40k?
SL3: 24k lux
http://www.youtube.com/watch?v=jho9rUPzp6E&feature=plcp
Quick specs:
JM26: 3.0A XML thrower with 60mm reflector. ~800 lumens
Side switch with 3 modes hold 2 seconds to turn on/off. Double click while on to activate hidden strobe.
1x 26650 or I can get 1x18650 to work even w/o a sleeve
SL3: 3x XML driven at 1.5A each (I know you guys want more!). ~1500 lumens
This SL3 has quite some throw to it, more than the Dry without a doubt
Hi Jake I just purchased the new thrower on your website, and I’m trying to also find info about these two you show here, can you give me some specs and info on them thank you.
I posted some quick specs I might be missing something but that should help out
Hi Jake
Do you have a link to your website? I’m fairly new round here :8)
I’m definitely in for an SL3 :bigsmile:
Cheers
Matt
My website is http://www.sbflashlights.com. These should be in stock in 2ish weeks due to the holiday
Thank you, def interested in the sl3! Since I just orders the k40 I might pass on the jm26
Great, thanks :slight_smile:
do you know approx. prices yet? is the head to the sl3 bigger than the skyray king?
you know comparisons between the two yet?
Whats the best 26650 cell for these lights?
Cheers
Matt
Price for the JM26 is goin be $64.99 before 10% coupon. SL3 will be $84.99 before discount. I don’t know how they compare to the Skyray
The cells we’re going to have in stock will be the 47s 26650s w/ 4000mAh of capacity. They’re good sells. I see the King Kong cells are popular as well. In regards to the best it depends on what you consider the best, capacity, safety etc
Is it easy to remove lens from JM26 to apply diffuser film?
I can’t grip the SS bezel good enough to remove it. I’ll have to ask Shadow if it’s glued down
Which throws better the K40 or the JM26? Do you have lux readings for either of them?
Jake are going to have the JM26 with a neutral tint?
Safest battery is the main priority, then whichever will supply the 4.5A to the SL3 with the least voltage sag, and best run time.
Cheers
Matt
Nice Jake,like ya site also.
So many lights and so little money.
Thanks for the heads up
DON…
The K40 runs circles around the JM26, no competition. I get 45k lux on the JM26 vs 80k lux on the K40
It will be glued. I applied some anti-adhesive (carefully) to my shadow JM07 and it came off pretty easy.
Neutral tint will be available for JM26 and SL3.
Don: Thanks!
Great news on the Neutral. Any idea if it will be 5000k, or …?
