Hello everyone,
Wurkkos is about to release another interesting EDC flashlight. It's called "FC11" and has some nice unique selling propositions that I would like to bring closer to you. For instance, it comes with a USB-C port for convenient and flexible recharging. Moreover, it uses the popular and powerful Samsung LH351D LED in neutralwhite tint (5.000K CCT) and 90CRI for high color rendition. For more versatility Wurkkos also implemented a magnetic tailcap as well as two mode groups (stepped modes and ramping).
Production is ongoing now and sales are expected to start by 11/11 sales with multiple options, i.e. purchasing with or w/o battery from AliExpress and Amazon.
Prices are not committed yet but it is expected to be below $ 30.00 with battery included.
Specifications
| Emitter | 1x Samsung LH351D 5.000K 90CRI |
| Max. ouput | 1.300 lumens |
| Voltage Range | 2.7V - 4.2V |
| Battery Options | 1x 3.7V 18650 Li-Ion Battery |
| Dimensions | 116,23mm (length) x 27mm (head diameter) |
| Weight | 65±1 grams (without batteries) |
| Reflector | Orange peel reflector |
| Lens | Toughened mineral glass lens, no AR-coating |
| Water resistance | IPX-7 |
| Driver | FET Reverse polarity protection |
| UI | Proprietary, with 2 mode groups (5+1 stepped modes, ramping mode) Mode memory Electronic lockout Timed stepdown from turbo after 90s |
| Special features | USB-C port Magnetic tailcap |
ANSI/NEMA FL1 Chart
Group 1 6 Modes |
Mode | Eco | Low | Mid | High | Turbo | Strobe |
| Luminous Flux | 2 lm | 50 lm | 300 lm | 700 lm | 1.300 lm | 1.300 lm | |
| Runtime | 275 h | 45 h | 9 h | 2 h 45 min | 1h 20 min | - | |
| Beam Distance | - | 28 m | 67 m | 104 m | 144 m | - | |
| Peak Intensity | - | 200 cd | 1.125 cd | 2.692 cd | 5.183 cd | - | |
Group 2 Ramping |
Mode | Ramping: Eco to Turbo | 1.300 lm | ||||
| Luminous Flux | 2 lm to 1.300 lm | 1.300 lm | |||||
| Runtime | depending on luminous flux | n/a | |||||
| Impact Resistance | 1 meter / 3,28 feet |
User Interface
Group 1: Stepped modes (default)
- Fast click to turn on; press and hold for 0.5 second to turn off
- Fast click the side switch to cycle through modes:
Eco → Low → Mid → High → Eco → Low → etc. - Doubleclick to activate turbo mode, one click to return to the previous brightness setting.
- Tripleclick to activate strobe mode, one click to return to stepped mode and previous brightness setting.
Toggle between Group 1 and Group 2
- press & hold the switch for 3 seconds from OFF. Two blinks will confirm the mode group change.
Group 2: Ramping
- Fast click to turn on or turn off
- Ramping: Press and hold side switch to ramp up or down. Ramping changes direction by pressing the button again within 1.5 seconds; same direction when ramping again after 1.5 seconds.
- The light flashes one time when it reaches floor or ceiling (both ends of the ramping range).
- Doubleclick to activate ceiling level ("turbo"), one click leads back to the last brightness setting.
- Tripleclick activates the strobe mode, one click leads back to ramping mode and last brightness setting.
Electronic Lockout (to avoid accidental activation e.g. in one's pocket or backpack)
- 4 fast clicks to lock the flashlight, the light flashes twice for confirmation.
- 4 fast clicks to unlock the flashlight. The FC11 will turn on in the previously used mode.
Some first pictures of a sample
As of 06/2021:
If you have any questions or comments, no matter if commercial or technical, please contact Wurkkos directly. Thank you for your understanding.
