Hey,fellows. I’m pleasure to present our newest Accessories : Brinyte USB 18650 battery.
No matter in traveling or in daily life, people is inseparable from electronic products, such like mobile PC, Pad, Power bank, camera, MP3….
With taking these electronic with you, we should take many accessories.
At least, chargers is necessary.
Without any charger, will you hangout two days?
I guess few people will answer this question without hesitation.
Many people will feel annoy to think to have to take so many chargers with.
Now, Brinyte new released patent micro USB charging battery can solve charger problem. One USB cable can make battery charged.
1.Brinyte direct charging lithium batteries 18650 is a tradition-based lithium-ion rechargeable battery upgrade products, with imported Panasonic 3400mah capacity cell.
The battery adopted innovation USB direct charging technology.
You only need one micro USB cable for it.
The battery is compatible to mobile charger, power bank or computer interface.
It is 4 hours that battery fully charged. This makes charging easier and more convenient.
Of course, this USB battery can be powered by charger.
2.Reliable and durable
The USB direct charging lithium batteries 18650 using imported Panasonic 3400mah large capacity cell, which makes charge and discharge cycles can reach 500 times at least.
It also adds a triple protected circuit board for Micro-USB charging interface. The battery provides anti-overcharge, over discharge and triple overheat protection functions.
3. Status indicator
In positive of USB 18650 lithium battery, there is a LED indicator with a two-color.
When using the Micro-USB interfaces for charging,red indicator turned on.
When its fully charged, the green indicator will on. Battery state ,safe and clear.
This bump design 18650 USB straight rechargeable battery length is 69mm, no difference with conventional 18650 lithium batteries.
No matter it is a flashlight, e-cigarette, or any other products, which use 18650 lithium battery, can be used in this USB Direct rechargeable battery.
Feel free to be charging!
