//v0 9/9/2014 by Everett
//initial version
//simple flashlight controller. mode change on power cycle
//version with red 12/3/2014
//added red channel for low red and safety flasher modes
#include <htc.h>
#include <pic10f322.h>
#define _XTAL_FREQ 8000000
__CONFIG(CP_OFF & BOREN_OFF & LVP_OFF & MCLRE_OFF & WDTE_OFF & PWRTE_OFF & FOSC_INTOSC & WRT_HALF);
#define pwm PWM1DCH
#define red_pwm PWM2DCH
persistent unsigned char mode;
enum mode{
max=0,
low,
lower,
low_red,
strobe,
ramp,
ramp_save,
#define max_mode 4
#define default_mode 0
#define safe_level 63 //25%
#define ramp_rate 15 //4 second ramp
#define ramp_save_min 33 //minimum time in ramp before it will be saved. in counts of ramp_rate (33*15=500ms)
#define ramp_pause 500 //milliseconds
persistent unsigned int password;
persistent unsigned char cycle_count;
persistent unsigned char level;
unsigned int ramp_save_timer;
unsigned int ramp_timer;
unsigned int v_timer;
bit v_sample;
#define voltage_rate 50 //milliseconds
unsigned char strobe_position;
persistent unsigned int on_timer;
bit direction;
#define storage_location 0x1f0
const unsigned char nvm[16] @storage_location={100,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
void delayms(int milliseconds);
void configure(void);
unsigned char read_voltage(void);
void initialize_mode(void);
void save_level(unsigned char input);
unsigned char read_level(void);
unsigned char lookup(unsigned char input);
void interrupt isr(void)
if(TMR0IF){ //fires at 1kHz
TMR0IF=0;
if(++v_timer==voltage_rate){v_timer=0; v_sample=1;}
if(ramp_timer){ramp_timer--;}
if(on_timer){
on_timer--;
if(on_timer==0)cycle_count=0;
void main(void)
configure(); //set up hardware peripherals
delayms(25);
if(password==12345){
if(mode==ramp_save){
save_level(level);
mode=low;
cycle_count=0;
else{
cycle_count++;
if(on_timer) mode++;
if(mode>max_mode) mode=0;
if(cycle_count>=12){
mode=ramp;
ramp_save_timer=0;
else{
cycle_count=0;
mode=default_mode;
password=12345;
initialize_mode();
on_timer=500; //if left on longer than this, stop counting cycles to enter ramp
ramp_timer=0;
direction=1;
GIE=1; //turn on interrupts
while(1){
switch(mode){
case lower:
case low_red:
break;
case max:
case low:
if(v_sample){
v_sample=0;
if(read_voltage()>87){
if(pwm>safe_level) pwm--;
break;
case strobe:
if(ramp_timer==0){
strobe_position++;
if(strobe_position>5) strobe_position=0;
if((strobe_position&1)==0){
red_pwm=255;
ramp_timer=35;
else{
red_pwm=0;
ramp_timer=75;
if(strobe_position==5) ramp_timer=900;
break;
case ramp:
case ramp_save:
if(ramp_timer==0){
ramp_timer=ramp_rate;
if(++ramp_save_timer>ramp_save_min) mode=ramp_save;
if(direction){
level++;
if(level==255){ direction=0; ramp_timer=ramp_pause;}
else{
level--;
if(level==0){ direction=1; ramp_timer=ramp_pause;}
pwm=lookup(level);
break;
unsigned int temp = input*input;
temp>>=8;
return (temp&0xff)+1;
pwm=0;
red_pwm=0;
switch(mode){ //initialize current mode
default:
break;
case max:
pwm=255;
break;
case low:
pwm=lookup(read_level());
break;
case lower:
pwm=5;
break;
case low_red:
red_pwm=25;
break;
case ramp:
level=0;
pwm=lookup(level);
direction=1;
break;
//fvr is at 1.024V. ADRES = 1.024/Vin*255. Vin = 1.024/(ADRES/255). voltage limit set to 3.0V -> 87. values below this correspond to voltage above 3.0V
GO_nDONE=1;
while(GO_nDONE);
return ADRES;
while(milliseconds!=0){ __delay_ms(1); milliseconds–;}
INTCON=0b00100000; //tmr0 only
T2CON=0b00000100; //on, no prescale
PR2=255;
TMR2=0;
LATA=0;
TRISA=0b11111100; //GP0,1 output
ANSELA=0b11110000; //
WPUA=0b11111100;
OSCCON=0b01100000; //8MHz
OPTION_REG=0b00000010; //8 prescale for 1ms interrupts
FVRCON=0b10000001; //1.024v to adc
ADCON=0b10111101; // fvr
PWM1DCH=0;
PWM1DCL=0;
PWM1CON=0b11000000; //on, output
PWM2DCH=0;
PWM2DCL=0;
PWM2CON=0b11000000; //on, output
GIE=0;
PMADR=storage_location;
PMCON1=0b00010100; //FREE and WREN
PMCON2=0x55; PMCON2=0xAA;
#asm
bsf PMCON1,1
nop
nop
#endasm //erased
PMCON1=0b00100100; //LWLO and WREN
PMDATH=0x34;
PMDATL=input;
#asm
bsf PMCON1,1
nop
nop
#endasm //write to latch
PMCON1=0b00000100; //WREN
#asm
bsf PMCON1,1
nop
nop
#endasm //write
PMCON1=0; //clear WREN
GIE=1;
