Thanks guys!
The plan is to ultimately anodize the tube black (dyed) and the head silver (not dyed).
I only used the solder thus far to join the two parts of the bezel.
Maybe i should boil it in soapy water to neutralize any acid that’s left?
Thanks guys!
I haven't heard of that before. Everything I've read is scrubbing with a brush and dishwashing detergent, rinse and do this about ten times. If boiling worked it would be a lot quicker.
I read that dropping a brazed part in boiling water helps loosen the flux. It seems to work as the flux becomes powdery and is easily removed. After that it gets soaked in a soda solution. Alu uses different flux and wire but I think both are acidic where electrical flux is not. Please let us know how it ages.
AARRGGHH!!
Blow off some steam here…
I found a tiny driver here!
i still don’t know where it’s from though…
But it was broken
Tiny IC with a broken leg and the coil just fell off…
So: AARRGGHH !!
I need to get some reading glasses soon…
This driver though, DOES fit in the mini pill…
Hope i get it to work again.
BUT IT”S SOOOO TINY!
i mean tiny
Edit:
EHRMAGEHRD, I FIXED IT !! :party:
Woot! Good to hear.
Looks like you are making progress! :) In case you need a hand, just let us know ok? :D
In case you have not seen it, you are going to like this.
Introducing the driver here
There’s a “2R0” resistor in series with the LED.
Can this be replaced by a lower R?
Or would that be too heavy for the little thing?
Got my Nichia’s in today
plus noctigon xp 16mm.
Bumpy…
Added some pics.
I think i’ll get it to work before i leave for France in 6 days.
Maybe i can even actually (more or less) finish it in time
Looks great!
Keep on working it!
A noctangular! Way to use the trace layout to your advantage. This contest has all the sizes from micro to mondo. :bigsmile:
It all fits, just. Nice going.
Really digging what you have done here. You're build is first rate.
Thanks for the kind words, guys!
Really appreciate it coming from you guys.
Still there’s a lot that can go wrong…
Just glued the TIR in the bezel with superglue, and the vapor tries to ruin the surface of the PMMA…
May have to do that over…
I’m isolating the ‘wall’ of the inner pill now with liquid enamel.
Hope i can wait long enough to harden
Updates soon.
updated…
see bottom of this post:
So close.
Gee that is tiny. I love that picture of the tiny noctigon you made. Keep it up :-)
Should we all keep distracting you from the build by typing here? 0:)
Almost there!
I like this tiny build.
I say don’t get hung up on waterproofing everything, unless you have the time. Function first, my build is dustproof at best. If the current is less than 1amp, 26 ga. wire should be sufficient, if that helps. I kind of liked the metal button cap.
…ughh…
Driver dead… :_(
It just doesn’t work anymore, for some unknown reason…
That sucks… :weary:
Not sure if i can get some replacement in time…
I’m leaving for France on tuesday…
A true bummer, friends…
