Like RBD said the board may clean up. Your not the first to create something as artistic as this mongeloid board and wont be the last. All the best for the next instalment.
Not a first attempt, but it’s my first S2 triple. The lathe is at work, it’s a Hardinge lathe they are somewhat common tool room lathes but in good shape they tend to sell for $5000 or more.
Cameras have limited dynamic range compared to human eyes. Reproduction of blue LED light is one of worst. We can clear see three different intensity in the pic though.
Some or all of the intensity difference is real, the amber LED is a lot dimmer than the red one. In real life there is a clear difference in the emitter colors, but all three are in the range for the red sensors, and they is no blue or green to detect.
The red LED is much brighter than the other ones in all the modes, I’m guessing that the VF to current curve is a bit different, if the three LEDs were in series it wouldn’t matter but in parallel it’s a problem. The only fix I can think of is to put a small value resistor in series with that LED, I think I can swap one of the jumpers on the Noctigon board with a surface mount resistor. I need to figure out what value resistor to use.
Right now it has a 4 7135 driver so 1.4A on high, and a very sub lumen low. At the same distance from my lux meter I get 50k on high and 5 on low, I need to bump the low up a bit.
You could drive the bright red led off of 1x7135 and the other 2 leds off of 3x7135. Keep the output from the two groups separate but the pwm together and they will all be controlled together.
I measured led voltage and tail cap current in the 5 modes for this light, I don’t know if it’s useful for anyone else but this way I can’t lose the info.
The Amber and the Red are XP-E2’s the red orange is a XP-E I couldn’t find anyone with all three colors in stock in XP-E2. The red is the brightest, and the amber is the dimmest.
