Hi people, hope you are doing OK.
I am writing this post as Efest batteries have been recommended to me a few times, but they are not what they seem. They don’t actually make their own batteries, they just re-wrap sony,samsung, LG and panasonics.
The Efest 3100 MAH 20AMP for example is actually around 9-10 amp continuous discharge( depending on the rewrap, some have been as low as 4 )! This might be OK in a torch, but I also vape, and regularly draw 17+amps, so they could go into thermal runaway due to this, and we know that is a very, very bad thing.
The efest 3100 MAH is actually B and C grade panasonic NCR18650BE and NCR18650BD batteries re wrapped by efest, BE’s are rated at 4AMPS continuous discharge, while the BD’s are rated at 10AMPS continuous.
The NCR18650BE 4 AMP batteries are no longer made, so are old B and C grade stock, which you can buy for around $4.
The NCR18650BD is in production and can be purchased for around $7 each, and they are A grade batteries, not rejects.
Hope this helps someone in someway, even if its just to let you know Efest are not very good to go for as they are B and C grade cells probably are not rated at what they was meant to, thats why they was rejected(Most likely with the NCR18650BE as they was meant to be 3200MAH, they would of been B grades at 3100MAH) or if your lucky a C grade 18650BD with 10 AMP discharge, and help you save some money.
You are much better sticking with Samsung, sony, LG, sanyo, panasonic, than re-wrappers of B and C grade batteries (Not all re wrappers use B and C grade, some rewrap with their own logo and just charge more money for the battery).
