It is a boost driver, it cannot deliver to 3V LEDs, the voltage output must be above voltage input, boost just means it boosts voltage.
The analogy that it is a 8A 3V driver which has been used by some before is actually misleading.
You could, however, reflow a 12V XHP50.2 on there and use this driver to deliver 1.9 (1.8?) Amps to it. Would be the same brightness as delivering ~7A to a 3V XHP50.2
Is the angle light going to have a head that sticks out like the Lumintop HL3A and Fireflies PL47, or is it going to be a more uniform body like the big brands?
Dammit… I guess I’ll be able to supply a side by side comparison soon enough, since I have a D4Sv2 with W2s, and I just ordered a D4Sv2 with the boost driver last night. Honestly, this might not be a bad thing for me anyway. Hot rod lights are fun, but it’s always bothered me that you can’t get max performance out of them for very long. What does one need in order to (hopefully cheaply) measure lumen output?
Measuring the lux with a ceiling bounce test would get you close enough to the relative brightness difference between the two configs and wouldn’t cost anything as long as you have a smartphone with a light sensor.
Question for all about the new Noctigon DM1.12 I know its channel switching but has anyone tried flashing it with tint ramp if so does it work I’m very interested in answering this query
thanks
This guy on Reddit did it. He chose to use the K9.3-tintramp-nofet hex though which is not ideal, because it disabled FET drive for the flood LED’s.
The reason he chose the NOFET version, is that the fet-enabled version will only allow the flood channel to be on above level 130. The best course of action is to use the K9.3-tintramp firmware that uses get, then set ramp ceiling to level 130. That will allow you to tint ramp up to the highest level possible (130) and you’ll still have access to FET turbo on the flood channel when you want it.
Sorry, the whole tint ramp / channel switch stuff still confuses me. Would you do this so that you would be able to tint ramp AND channel switch on the DM1.12? Thanks!
Unfortunately not. K9.3’s firmware has not been updated to include the option to tint ramp or instant switch. Currently they are separate firmwares. It (and DM1.12) come with the instant switching firmware by default. The K9.3 tent ramp firmware can be reflashed onto either, but it only does tint ramping.
TK may merge them in the future but that has not happened yet.
Edit: DerMaxPower says the k9.3-tintramp-nofet firmware does have both tint ramping and instant switching.
We have tried it, but it seems that the 519A LED dome is a bit too big for the optics,
and the dome will be cracked by the optics, so, it will not fit.
