Hey Guys!
I got a Kinfire K1200S from gearbest for a Review…
at first: some data from their website:
Emitter Type: XM-L L2
Total Emitter: 12
Lumens: 8700
Battery Quantity: 6 x 18650 (Not included)
Mode: 5 (High > Mid > Low > Strobe > SOS)
Focus: No
Rechargeable: No
Waterproof: IPX-6 Standard Waterproof
It came in a “Courui” Box (togehter with the Olight i3s i reviewed earlier)
a BIG Light!
a SK68 - XinTD X3 - HD2010 - K1200s - Skyray 3xT6 - Solarstorm T3
the laserengraving is well done, the anodisation is okay - but on the slippery side
tailstand is possible!
did i say its big?
the tailcap hast 3 recesses and 3 holes for lanyards
“tactical”grip is possible - kind of
looking at the front end you see 12 Cree XM-L2 sitting in small reflectors
the lens doesnt seem to be AR coated, but its very clear!
the emitters are well centered (mostly)
the bezel is not glued - but not reased also (neither are any other threads)
the backside of the reflector is flat
the “head” is not very massive - so i think heat coulb be a problem
emitters are wired 2S3P - in 2 channels -> 12 in total
i tink you can see how thin the base is…
lots of thermal grease is used
the centering rings are very small
on the back side of the head you see a plastic retaining ring and a quite massive contactplate made from brass to prevent the cells scratching the driver (i like that!)
uuhm - not soo massive - but does the job well
batteryside of the driver
veery thin wires ![]()
the “shoulder” (aka driver compartment) is easyli removeable - some times it opens before the batterytube…
all in a row
the driver - a HX-1337a
aah - there is the second one ![]()
the battery tube is very massive and blank on the drivers side to make good contact
batteries are 2S3P
the tailcap side is anodized everywhere
the rubber cap of the switch is exchangeable
the switch
at last - a beamshot…
left is the reviewed light - right is the older XM-L version i got earlier
both lights on low (shows PWM - which i can hear, but dont see it irl)
maybe i got a warmer tint?
that would explain why the L2 Version i got is not much brighter than the L Version…
short conclusion:
a nice light – but for me a little bit too big
if i can pump up the Lumens – it will be okay (never believe the “China Lumens” !)
overall a good light, but i think forr 100 bucks there are better ones.
but stay tuned for the modding!
