KronoReview of the Odepro M37 . This item was provided by BangGood/Neal for review.
^ Product page/website pics. ^
This is the third light I have reviewed from Odepro. Odepro is part of Brinyte. Odepro must be their budget-oriented line of lights. They are reasonably priced, and offer decent features for their price-points. The M37 is a keychain light with some common design elements with premium flashlights. A little info from BangGood first:
BangGood regular price: $13.59.
Specifications (From BangGood product page):
My notes in underlined bold italics:
Product name: Odepro M37 CREE XP-E Q5 EDC LED Flashlight
Brand: Odepro
Model: M37
Emitter Brand CREE
Emitter Type: XPE-Q5
Material: Aircraft-grade aluminum body
Mode: low,middle,high,strobe,sos
Battery Configurations: 1 x aaa battery(not included)
Circuit: constant current circuit,memory control
Switch Type: clicky
Switch Location: tail of the flashlight
Brightness: 230lumens
Range: 60meters(max)
Runtime: 3hours
Lens: high quality toughened optical lens
Reflector: Aluminum alloy plating mirrir reflective cup
Carrying Strap: included
Waterproof: IPX-8 waterproof
Color: black,red
Weight: 20g without battery
Size: 72mm x 14mm(length x body diameter)
Package included:
1 x Odepro M37 CREE XP-E Q5 EDC LED Flashlight
My added specs:
Lens OD: Estimated at 12mm.
Lens thickness: Unknown.
KRONOREVIEW:
The Odepro M37 is a single AAA flashlight with a single, cool white, XR-E emitter. The flashlight comes with a thoughtful, swiveling keychain-type connector. It is shipped with ample protection in a sturdy, cardboard box. Light is controlled by rotating head (twisty). The body is only two pieces: Head & integrated battery tube/tail. There are 5 modes (L/M/H/Strobe/SOS), and the M37 has last mode memory. This light looks very similar to my Fenix LD01. I have taken several photos, including shots of the M37 with the LD01. I have been EDCing the M37 for 3 or 4 weeks now, so you might notice my pics show normal wear of the annodization on the edges. It will work with a 10440 battery, but it is not ‘officially’ 10440 compatible. The Odepro M37 is available from BG in either black or red.
HIGH-LIGHTS:
Solid construction.
Glass lens.
Plenty of knurling and ridges for one hand operation/grip.
HA-III matte black coating (my sample).
Reverse polarity protection (confirmed).
Last Mode Memory.
Beam pattern has a nice hot spot, helps throw quite a bit for this small of a light.
Plenty of triangular threads.
Tailstands with or without keychain connector.
AAA and 10440 compatible.
LOW-LIGHTS:
Older emitter.
Little to no thread lube.
No AR lens.
Tint leans slightly towards purple.
Questionable modability (Unable to figure out how to remove driver/lens/reflector etc. Driver appears somewhat loose, but way down inside of head. Nothing to really grab hold of, and there is no separate bezel to access it from the business-end).
PICTURES
Packaged in a nice cardboard box.
Well protected on inside with ample foam packing. Just light and keychain connector.
Standing on bezel.
Tailstanding.
Sideview w/Odepro logo.
Sideview w/battery orientation logo.
LED view. XR-E emitter. Smooth reflector.
In hand.
DECONSTRUCTION (Not much to it. Sorry, unable to disassemble head).
Head separated.
Inside head, cathode contact side of driver. Upside down Brinyte logo on back of driver.
Inside battery tube.
Comparo pics. Fenix LD01/Top and Odepro M37/Bottom. M37 is about 2mm shorter.
BEAMSHOTS/NIGHTSHOTS:
Wallshots.
Beamshot closeup on stained concrete floor.
Side beamshot.
Comparo wallshot. Fenix LD01/Left and Odepro M37/Right.
Control shot.
High beam shot (AAA battery-Energizer Alkaline).
High beamshot with 10440 battery (MarsFire).
SUMMARY
Odepro continues to build lights that provide quality features at budget-conscious prices. This trend continues with the M37. The look and feel is very good for the price. HA-III anodization, lots of threads, smooth, twisty operation (once lubed), option of AAA or 10440 battery, attractive, Fenix-like design…overall a nice light for the price. It take a few hits though. The older XP-E emitter that has a slight, purplish hue, as well as its apparent lack of modability. Overall though, a properly priced light that is a good choice for gifting.
Note: I see that others have experienced flickering with their M37s. I have not experienced that with my sample.
KRONOMETER patented rating: 3.5 out of 5.
