Well SWMBO is NOT to happy about this so instead of having to take it out to my mom's and lock it in my safe I keep there I figured I'll try to sell it first (she doesnt want it around the kid's who love to play with all my lights).
The light is a brand new Solarforce L2C host I bought just for this build, the emitter is a brand new LEN ENGIN LZ1 365mn UV single die emitter, the driver is a 105c with 4x 7135's for 1.4A with all components (including C1) moved to the top. High only with double click for strobe. I'm using a M1 masterpiece pro pill (which is machined instead of stamped) for the added mass under the emitter and is foil wrapped for a tight fit. Also, I fit the LED on a xml-color sinkpad so its DTP (why I'm able to overdrive it slightly). It has a clear switch boot, FWD clicky and even tho it doesnt need it at <1.5A the spring is braided. If you really want I will reflash it to add modes but there's really no reason to have modes with a UV light and at such low current its not like you need to extend the runtime with a low or anything, really single mode is all you need.
If you're looking for a UV light this is the real deal, not like 405nm. There is almost no visible light (in my light box it measures 10Lm) but an extreme amount of UV. It makes EVERYTHING glow, infact some stuff glows so bright it actually gives off MORE visible light than the emitter does! DO NOT LOOK INTO RUNNING EMITTER, same goes for a reflection of the emitter, do not point it at your face at all, ever, period! You assume all risk. Because of the danger associated with UV you must be 18+ for this one.
Price is $100 and includes tracked / insured priority shipping in the US, international add $15.
mouseover for emitter on (no dirt / scratches on the reflector / lens / glass dome, anything you may see is just a little dust on the outside of the lens)
charges GITD instantly, also notice the day of week wheel glowing on my Seiko 5
Newly added nitecore grip ring
Thanks for looking!
