LED test / review - Lumenpioneer LHP531 - all CCT (1800, 3000, 4000, 5000, 6500 K 70 CRI) - very popular 5050 LED with good beam and very good price
LED test / review EN
Lumenpioneer LHP531 (5000 K + all CCT)
various bins
2025-08-04
  • Type: multi die, flip chip
  • Bin: various
  • Color group: various (1800 - 6500 K
  • CRI: 70
  • Rated voltage: 2.6 - 3.2 V
  • Max. Forward current: 9,000 mA
  • Max. Peak current: — mA
  • Viewing angle: 120 °
  • Thermal resistance: 2.25 K/W
  • Max. Temperature Tj: max. 150°C
Datasheet can be downloaded here: LHP531 (cool white only), 0.8 MB
This is probably the largest LED test ever conducted, with five CCT variants (1800, 3000, 4000, 5000 and 6500 K) of one single LED type tested simultaneously. In addition, the LED is disassembled and close-up images of the LED chip and substrate are shown.
The emitters tested here come from a Convoy order placed in mid-July 2025. Many thanks to German flashlight forum (TLF) user @J0hn for providing a large number of LEDs, which made this extensive test possible in the first place!
The LHP531 is a flat 5050 LED without a dome. Nine LED chips in a flip chip design are arranged in a 3x3 pattern on the ceramic substrate. The relatively close arrangement without clearly visible gaps should result in a good light pattern. A white, relatively stiff silicone compound has been poured around the phosphor-coated LED chips.
The footprint offers no special features. 5050 boards are fully compatible. The LHP531 can only be operated at 3 V; 6 V connection is not possible.
Depending on the CCT, there is a slightly yellowish border around the nine LED chips. As the CCT decreases, the phosphor becomes increasingly reddish in color. The light-emitting area is 13.5 mm² (1800K: 14.3 mm²).
  • at 9,000 mA (official maximum current): 3298 lm @ 3.03 V
  • Power at official maximum: 27.3 W
  • Efficiency at 9,000 mA: 121 lm/W
  • Maximum reached at 25.4 A, at this point 5952 lm @ 3.44 V
  • Power at maximum 87.3 W
  • Efficiency at maximum 68.2 lm/W
Data for 25 °C Tsp (at 85 °C the luminance values are around 13 % lower).
Due to the already extensive scope of testing, the LHP531 is only compared here in terms of its various CCTs. For comparisons with other LEDs, please refer to my existing tests. All in all, it offers high performance. It is interesting to note that the maximum current decreases with warmer CCTs. This is probably due to the increasingly thicker phosphor layer and the associated reduced heat dissipation.
Only the 1800 K variant stands out with a significantly lower luminous flux. Up to 3000 K, the LED offers a relatively constant high performance. However, it should be noted here that the LHP531 is currently only available in 70 CRI. If high CRI variants appear at some point, a significantly reduced performance is to be expected.
The specified flux bin is almost always missed. To the best of my knowledge and belief, measurement errors on my part can be ruled out, although I cannot guarantee this, as my measurements are always compared with (non-accredited) reference light sources. The 1800 K variant achieves the flux bin specified in the order code.
The forward voltages of all variants are very close to each other, which indicates precise binning of the chips. The 1800 K variant performs best in this respect.
The luminance decreases proportionally to the measured luminous flux with warmer CCT. The 6500 and 5000 K variants are certainly suitable for throwers, although single-die LEDs with a considerably smaller luminous area, such as the SFT-40 or SFT-25R, have a significantly higher luminance.
After the test, two LHP531s were damaged (3000 and 5000 K). After 15 minutes of operation at maximum possible operating current, black spots formed over the light-emitting surface. These are embedded in the silicone or phosphor and cannot be wiped off, even with alcohol.
Interestingly, these black spots did not grow larger after several hours at maximum possible current. However, operation with such (pre-existing) damage is not recommended in any way, as this can destroy the LED in a short time. Due to the seemingly random occurrence of such damage, contamination with some dirt/foreign particles in the phosphor or silicone is suspected, so that in principle any CCT could be affected.
Without the phosphor layer, the chips glow in the typical blue color (peak 450 nm).
The LHP531 is equipped with nine chips. These are said to have been manufactured by Sanan. An LHP531 6500 K was disassembled to obtain the detailed images.
The connection layout on the ceramic substrate is clearly designed for 9P configuration only. All chips are connected in parallel.
The beam in OP reflectors is excellent (pictured: 1800 K version in an OP reflector of a Convoy S2+). In SMO reflectors, depending on the geometry and focus, there may be minimal artifacts such as donut holes, but these are never distracting. This is generally more the case with cool white LEDs, as the phosphor layer is generally thinner with these CCTs and gaps between the LED chips are therefore more noticeable in the beam.
1800 K
3000 K
4000 K
5000 K
6500 K
1800 K with added cyan component:
The spectra themselves offer little surprise. The variants down to 3000 K offer the typical spectrum of a white LED with a very pronounced cyan hole and low red content. The color rendering index is therefore naturally low. Only YAG:Ce3+ and YAG:Gd3+ are used here in various emission peaks (for the neutral and warm white variants).
The 5000, 4000, and 3000 K variants offer a partly strong pink tint. The 6500 K variant is slightly above BBL. The deviation of the color is relatively low, but still present (only 5000 K variant tested, sample size n=5):
Sample No. / CCT, Ra/R9, duv
#1: 5429 K, 73/-25, -0.0044
#2: 5381 K, 73/-28, -0.0024
#3: 5260 K, 73/-30, -0.0023
#4: 5348 K, 72/-26, -0.0046
#5: 5373 K, 73/-29, -0.0024
The 1800 K variant, on the other hand, is interesting because, unlike the NTG35/FFL351A 1800 K, for example, it is not a classic full-spectrum LED. Instead, it corresponds very closely to PC Amber LEDs. These were primarily developed as a replacement for sodium vapor lamps. This means virtually no blue component and an emission peak at around 600 nm, which is generated almost exclusively by SSN phosphor.
The tint is very distinctly yellowish (positive duv), which is typical for PC amber LEDs; see also the test of an older XP-E2 PC Amber. Such LEDs are not suitable for ambient or mood lighting, as the colors are greatly distorted and the saturation is low. As soon as even a small amount of blue or even cyan is added (see spectrum), the CCT increases minimally, but the duv decreases significantly and the color rendering index increases significantly.
The LHP531 1800 K is therefore not suitable for normal lighting applications. For classic lighting tasks – especially indoors like living spaces – full spectrum LEDs with the highest possible color rendering should always be used.
5000 K variant:
  • Ra: 73
  • R9: -25
  • CCT: 5429 K
  • duv: -0.0044
The LHP531 generally does almost everything right. Good beam (especially at warmer CCTs), good tint (as far as available in later batches), an extremely affordable price, and full compatibility with (even older) 5050 boards make it a good choice for retrofitting existing lights.
The biggest drawback is the unachieved flux bin and the 1800 K variant, which is not suitable for everyday lighting and also falls well short of its specified color rendering index due to the PC Amber spectrum. On the other hand, it is one of the very few PC Amber LEDs that achieve more than 1000 lm, making it particularly interesting for modernizing sodium vapor based street lights.
I also hope to see high CRI variants and a true full-spectrum 1800 K variant soon, which would significantly expand the range of applications once again.
Thank you for reading this test. :slight_smile:
Greetings, Dominik
v1.0.2
LED test proudly made in Germany :germany:
44 Thanks
Thank you very much!
From the power comparison:
This means, they all achieve around 160Lm/W at 10W, right?
So essentially we’re talking about XHP50.3 equivalent when it comes to brightness but with much less throw due to larger LES. All of them also seem to be below the minimum for the W3 bin - 520lm at 1A, 3900lm at 9A, meanwhile your samples scored below 3400lm at 9A. I’m not impressed.
Efficacy at 10 W:
1800 K: 113 lm/W
3000 K: 142 lm/W
4000 K: 148 lm/W
5000 K: 152 lm/W
6500 K: 153 lm/W
The 5000 K variant has almost the same efficacy as the 6500 K variant.
11 Thanks
An incredibly well-controlled and thorough test! It is very enlightening to see the internal construction of these emitters.
It is amazing that the lower CCTs maintain almost the same efficacy as the higher CCTs, with consistently good tint. Looks like they’ve figured out a good phosphor mixture.
The point of this emitter is not to beat the XHP50.3 HI in throw, but to offer high-efficacy flood in 3V, good tint, and a wide CCT selection, which is not available in any of Cree’s XHP series.
The power handling is significantly better than XHP50.2, which in turn is better than XHP50.3 HI, which is occasionally plagued with premature failures under usual operating conditions (burnt phosphor).
The throw difference could be smaller than expected–the XHP50.3 HI exhibits sideways leakage due to the transparent silicone, which reduces throw and worsens tint. It’s unclear which one would have greater throw at maximum drive current, since the LHP531 also attains higher output at maximum.
10 Thanks
Not to forget it is fully compatible with 5050 footprint which enables easy drop-in upgrades for older flashlights, especially those with XM-L(2) and OP reflectors.
Quite a short week, huh
It doesn’t explain why it’s 500lm below minimum bin at 9A. Below their own specs. That’s the problem.
You are wrong. I have a proper sphere since 2024.
Maybe it is better to correct the wrong information you wrote.
Just be glad that someone is testing LEDs and is even managing to do so earlier than originally planned.
18 Thanks
I am. Thanks for the test.
I believe this was sarcasm/Verbal Irony because they know it was a lot of work.
6 Thanks
I agree that the LED is seriously underspec, which is a shame. But it still performs ahead of all comparable alternatives, and that makes it good in my book.
6 Thanks
@Simon_Mao whats up with the binning? Says up to 4500 lm on your site.
Since I do not have any officially calibrated reference light sources (only unofficial ones that have been calibrated with an integrating sphere), I cannot guarantee the accuracy of my measured values.
However, measurement errors of 10 % would be noticeable since other LEDs net the given specification. And since at least my sample of the 1800K variant is within the specifications, there must be some form of deviation from the flux bins given in the official datasheet.
You’re getting like ~3.7K lm at 10A? That’s ~18% lower than 4.5K if my math is mathing.
Thank you for the test either way!
With a deviation of more than 15 percent from the specified values, this can no longer be explained by measurement errors in my setup. (This is what I explained to another forum member some time ago, where LEDs inexplicably had a significantly lower luminous flux as stated by the manufacuterer / datasheet. The deviation is too large to be just a measurement error on my part).
7 Thanks
First - thanks for your work.
As a LED knowledge newbie - how do you assess from presented data whether a LED is suitable for throwing?
I ask because I am on the verge of getting myself a LHP531 filled 3x21C, and the only dilemma for me is CCT: should I get 4000K or 5000K. If 5000K LHP531 throws much better than 4000K - that would most probably prevail for me.
Again thanks for your endeavor.
Useless lumen chasing :slight_smile: To see x2 brightness we need x3-x4 more power. Running at 3amps we need to increase power to 12amps to see perceived x2 brightness.
6 Thanks
It is mostly about luminance. LEDs with smaller LES have in most cases higher luminance, or can reach at least the same luminance at much lower power as the LEDs with big LES.
So it is always a tradeoff between light flux (and power / heat) and luminance. There are a few more factors, like thermal resistance etc but in general the luminance is the most important metric here.
