LED test / review
EDIT 2023-02-07 — I dedomed the SST-12, you can find the results for flux and luminance incl. color measurement in this post!
LEDs with round LED chips seem to become more and more interesting. After “Yinding” launched an LED with a round luminous surface in the XM footprint (test here), Luminus now also offers an LED with a round luminous surface, although it is smaller than from the “Yinding” one. The round luminous surface should significantly improve the behavior in optics and increase the luminance.
This test will clarify how well this LED performs compared to competitors.
Tj 85 °C / 700 mA
Type: single die, domed
Binning: min. H3 (min. 267 / max. 285 lm)
Color kit: 502 (DA, DB, DC, DD ≈ 5000 K)
Rated voltage: 2.5 to 3.1 V
Max. forward current: 1,800 mA
Max. peak current: 2,400 mA (130 °C Tj)
Viewing angle: typ. 120°
Thermal resistance: typ. 4.9 °C/W
Max. Temperatur Tj: 150 °C
Official datasheet here (Luminus, PDF)
The round luminous surface, which sits on a gray substrate with a white silicone coating, is particularly striking at first glance. The dome is made of clear silicone, the white coating around the luminous surface seems to be an extra layer that is cast in an extra work step before the dome is applied.
It is interesting that the LED chip used here is connected with bonding wires, which is no longer implemented for many LEDs today. In this case, this was probably chosen because of the round light-emitting surface and the fact that the light-emitting surface is not shaded anyway.
This LED is otherwise similar in design to the XP-E2. It also becomes apparent relatively quickly here that the XP-E2 is the direct competitor, as the operating parameters and electrical properties are very similar.
Due to the symmetrical design, centering rings made by lathe can be used without any problems. In general, accessories for XP LEDs (3535) are fully compatible.
The footprint corresponds to the well-known XP format. The thermal pad is electrically isolated so that DTP boards of this format can be used without any problems.
A special feature is the round luminous surface. This additionally sets this LED apart from existing models. Round luminous surfaces are known so far rather from large COB LEDs, in which several small luminous surfaces are arranged in a circular area. In the SST-12-W, the round luminous surface shines absolutely evenly. Remarkable here is the very sharp delineation of luminous area, which indicates the use of a chip of the classic lateral design - today’s LED chips usually also emit light at the sides to increase the overall efficiency, but this often causes problems with color fringes in reflectors (see XHP70.2).
The round light emitting area is 2.64 mm² in size. Due to the round shape, no light is lost due to shading at the wires despite the use of two bonding wires.
Official parameters:
- at 1,800 / 2,400 mA (official maximum current 150 / 130 °C Tj): 601 lm @ 3.20 V / 709 lm @ 3.33 V
- Power at official maximum: 5.76 / 7.99 W
- Efficiency at 1,800 / 2,400 mA: 104.3 / 88.7 lm/W
The official maximum currents are already very high. In contrast to many other LEDs, where the maximum current is specified rather conservatively, the performance increase due to overcurrent is unusually low. Possibly this is for marketing reasons, but I don’t know exactly.
The Vf is in the normal range, it is not extremely low as with some Lumileds emitters, but also not as high as with XP-E2 or XP-G2 (old version).
Overcurrent:
- Maximum reached at 3.20 A, at this point 771 lm @ 3.49 V
- Power at maximum 11.17 W
- Sweet spot at about 2 A (642 lm @ 3.24 V)
- Power in the sweet spot 6.48 W
- Efficiency at maximum 69.0 lm/W
- Efficiency in sweet spot 99.1 lm/W
I do not recommend overcurrenting. The power increase is very small. Interestingly, even operating at 2.4 A (official maximum current at 130 °C Tj) is not really recommended, since there are hardly any safety reserves left and at higher ambient temperatures the Tj of 130-150 °C could be significantly exceeded.
At 2-2.1 A, operation with a 6*7135 driver is possible without any problems.
The old XP-G2 S4 2B with the smaller light area as well as the Black Flat offer a significantly higher luminous flux and pull away mercilessly thanks to their considerably higher overcurrent capability. The Black Flat offers about the same Vf as the SST-12, but reaches a significantly higher maximum current of 5.8 A.
The luminance is not very high. Interestingly, the luminance of the SST-12 is only minimally higher than that of the XP-E2 R4 despite a significantly higher luminous flux, and that only when the maximum possible current is used. The luminance stated here was confirmed both with the reflector measurement method and by means of direct measurement at 1m. The only minimally increased is mainly due to the larger luminous area than the XP-E2.
The SST-12 is not recommended for extreme throwers. Here I consider the XP-E2 (if it depends on higher luminance at low current and the higher Vf is little relevant) more useful. Alternatively, a CSLNM1/PM1.TG or Black Flat HWQP can be used, whereby the latter has no electrically neutral thermal pad and the conversion with this LED is therefore much more difficult.
The SST-12 tested here produces a greenish light, especially at lower operating currents.
A duv of 0.0062 @ 350 mA is relatively high, at 50 mA this is 0.0098. The color rendering is also not usable, an Ra of 67 and an R9 of -40 is very low, whereby this LED is basically only available in this CCT in the range of typ. 65-70 CRI.
There are no other surprises in the spectrum; it is typical for a neutral white LED with low color rendering.
However, at this point I would like to say a few words about Luminus newer products in general.
I have already tested several LEDs from this manufacturer, even though I have not published a separate test for each emitter. All these LEDs are visibly green, which is why I will not recommend a single emitter from Luminus when it comes to color and light quality. The source of supply doesn’t matter in this regard, as LEDs from Aliexpress, Kaidomain, as well as Mouser all have the same green tint, making this independent from seller or date code.
I don’t like this development. Low color rendering is one thing, but greenish tinted LEDs were and are basically not very popular, especially when a somewhat higher demand for light quality is essential. Few years ago, Cree showed with the MT-G2 how low CRI still looks good enough for flashlight use, even for today’s standards. The green tint also occurs in the variants with high color rendering (4000 K SST-20-H, for example), whereby the color saturation also suffers here - the Ra is nominally very high, but the color rendering felt is still not very good.
The Nichia 519A provide a minimally reddish light (we know this as ‘being rosy’), but this increases color saturation and subjectively looks very good. Why Luminus does not pay more attention to the tint and at least offers special binnings with negative duv is beyond me. Technically the emitters are without question very good, only the light color is not. Of course, there is the possibility that special color binnings are available, but as long as these do not reach the broad mass market and are available at wholesalers, I wonder why this area of good light color remains reserved almost exclusively for Nichia.
In reflectors, the light image is very good. Depending on the quality and calculation of the reflector, rings can appear around the spot, but the spot is still sharply defined. Spill is only slightly present, most of the light is concentrated in the spot. There is no color distortion in spot or spill.
The statements from the Yinding 5050 test also basically apply to the SST-12; due to the circular luminous surface, this LED is also well suited for use in zoom optics (lenses).
The SST-12-W is one of the first LEDs from a well-known manufacturer with a dome and circular luminous surface. The circular luminous surface provides an excellent light pattern in secondary optics, and the Vf is relatively low.
I like less the greenish light color and the low luminance, which makes LEDs like CSLNM1/PM1.TG or Black Flat HWQP and even the old XP-E2 seem more suitable for thrower applications at lower operating current. In addition, overcurrenting makes little sense, and the manufacturer’s specifications are already set very high here.
Pro
- XP footprint
- circular light area, therefore very good light image in secondary optics
- reasonable price
Neutral
- Luminance on the level of the XP-E2 R4
- overcurrent is hardly worth
Contra
- high thermal resistance
- Poor color rendering and green light color
Thanks for reading the test! ![]()
Many greetings, Dominik
