Quick test of the Seoul Semiconductor SunLike SMD3030 LED.
What makes these interesting is the smooth spectrum rivaling and exceeding that of the Nichia Optisolis.
Datasheet: http://www.seoulsemicon.com/en/product/spec/\_91_SunLike_92\_%20STW9C2SB-S/31
Part name: STW9C2SB-S
Forward voltage: 6V
Max current: 200mA
CRI: Min. Ra 95, R9 85
Luminous flux: Min. 83-104 at 150mA depending on CCT and flux bin
Efficacy: ~108 lm/W (again depends on the bin)
Emitter package size: 3x3mm
I got these from user SunLike from sunlikelamp.com
The unusual size and solder pad configuration combined with 6V forward voltage (also available in 3V, which djozz tested previously) makes these a bit difficult for most flashlight modding purposes. Can’t use the normal 3535 XP MCPCB for these.
An MCPCB for Optisolis, such as the VR10S1-757 from virence.com could probably be used for these as well. My emitters were reflowed on a board from SunLike. These are used on a variety of bulbs he also sells.
Previous bulb tests with SunLike 3030:
Remez SunLike E14 LED bulb (3000K, CRI95)
Remez SunLike E27 LED bulb (5700K, CRI95)
SunLike8 SMD SAW E27 LED bulb (4200K, CRI98)
Output
I tested the 5000K LED for maximum output and tint shift with increasing current.
Output peaks at 228 lumens at 500mA / 3.7W.
Tint behaves quite predictably and turns quickly more magenta after the peak output. At the nominal driving current of 150mA the tint is very close to daylight, which isn’t surprising considering the LED’s name.
CRI data for all the emitters
Excellent CRI and very pleasant tint on the warmer versions, while the higher CCTs are tracking the daylight tint above the BBL.
3000K
4000K
5000K
5700K
