2026-10-20
- Type: flip chip
- Bin: —
- Color group: —
- CRI: 90
I got this emitter some weeks ago from BLF user @billy_s, thank you very much for that. There is no datasheet available.
The DD7036 is a domeless LED with 36 chips in 7070 footprint, hence the name (70 = 7070, 36 = number of individual chips). Due to the high CRI phosphor mix the surface is orange-yellow.
The chips are made by Sanan. The LES is 44 mm² in size.
- Maximum reached at 52 A, at this point 10029 lm @ 3.48 V
- Power at maximum 181.1 W
- Efficiency at maximum 55.4 lm/W
Data for 25 °C Tsp (at 85 °C the luminance values are around 13 % lower).
The DD7036 has a quite low thermal resistance since the thermal maximum of 180-200 W for standard 7070 footprint is largely used. The light flux is quite high, considering the high CRI phosphor which lowers efficacy quite a bit. It is way below the 15000 lm stated by the manufacturer, though.
The luminance is quite low, but to be fair, basically the whole surface is covered with chips. I still would not use these LEDs for thrower builds.
The thermal image shows a problem which should apply to most - if not all - of these “CSP style” emitters, which have basically the whole emitter surface covered with chips - the chips on the edges are prone to overheating due to not being directly on the thermal pad. Likely this limits the maximum power as well.
The tint is good. It is completely neutral without any annyoing tint. A more rosy version is planned for the future, although for that the amount of red phosphor is likely the only thing changed.
There is a multiphosphor mixture used, likely consisting of YAGG:Ce3+, YAG:Gd3+, SSN and likely SCASN for red (CASN has way too much energy in IR range which lowers efficacy drastically).
This type of phosphor mix is relatively easy and cheap to achieve, which is crucial for small-quantity production runs.
- Ra: 95.6
- R9: 93
- CCT: 4418 K
- duv: -0.00097
A nice emitter, but with relatively low luminance, which was to be expected. This version has a really neutral tint, a more rosy variant is planned.
I am not so sure about the problem with overheating chips on the edges, though.
Thank you for reading this test. ![]()
