2024-05-24
Link to original test: Klick
- Bin: unknown
- Color group: unknown (3000 K)
- CRI: 95
Attention: Data sheet not available as of 24.05.2024.
The emitter was purchased from Kaidomain in May 2024.
The most striking feature compared to the already tested cool white SFT-70 is the significantly more orange luminous surface, which is typical of warm white LEDs (especially those with a high CRI). The design and footprint are otherwise identical to the cool white variant and require no further explanation.
- at 7000 mA (official maximum current): 2183 lm @ 6.99 V
- Power at official maximum: 49.0 W
- Efficiency at 7000 mA: 44.6 lm/W
- Maximum reached at 9.6 A, at this point 2389 lm @ 7.48 V
- Power at maximum 71.8 W
- Efficiency at maximum 33.3 lm/W
Data for 25 °C Tsp (at 85 °C the luminance values are around 13 % lower).
As with the cool white version, the achievable increase in luminous flux above the official maximum flux is low. In the absence of a data sheet for the warm white SFT-70, the official maximum luminous flux of the cool white version is assumed here. As with the warm white SFT-40, the efficiency of the maximum possible luminous flux is very low and corresponds to that of an overcurrent halogen lamp.
Nevertheless, this LED offers a higher output than the SFT-40 can deliver, and the luminance is high enough for throwers. The LED tested here was not damaged after running at maximum current for over 5 minutes.
The beam corresponds to that of the cool white SFT-70 and there are no disturbing artefacts or rings. If an SFT-70 in cold white offers a good beam in a given optic (reflector or lens), a 1:1 emitter swap is easily possible.
The light quality is simply perfect. There is no annoying tint, apart from a slight reddish tint (‘rosy’), which is hardly noticeable due to the warm CCT and makes this light even better. The colour quality is very good, the high colour rendering value is particularly evident when compared to other 70 CRI LEDs with the same CCT.
- Ra: 94
- R9: 89
- CCT: 3114 K
- duv: -0.0032
Luminus can do warm white. The SFT-70 3000 K 95 CRI provides a very beautiful light, can be replaced directly with 6 V-XHP50 LEDs or other SFT-70 emitters thanks to the 5050 footprint and has a higher output than the SFT-40 in the same CCT.
Thank you for reading this short test. ![]()
