I’m okay with the head being 1.5 inches wide. I’m not a fan of sharpie sized lights, I don’t care about weight either, but do want them to b remotely pocket sized.
I’m already aware of Zebralight sc700, convoy s21d, acebeam e75,e70, sofirn sc33, are there others?
I’m also aware that olight baton 3 pro max can do almost 700 lumens for almost 2 hours.
I’m not sure which graph is correct, but they’re both impressive. They could both be correct, if the ambient temp was vastly different (winter vs summer testing, for example.)
Edit: I forgot to mention the Sofirn SP33S. Another really good light for sustained brightness, at least in high mode and not turbo (as long as you’re OK with it being 26650. Some don’t like the girth.)
Ah, OK. I didn’t realize that the 70.2 and 70.3 were so different from each other (electricly speaking, the tint shift is clearly way worse on the 70.2.)
Those all use old drivers, mostly linear. The Lume X1 Is a highly efficient boost, same as in some (most?) newer FFLs.
Sustained brightness almost exclusively depends on the physical size/surface area of the host and the driver. And ofc on LED choice, but that’s a given.
As for the older Emisar lights, I see that the D4K even with the older boost driver manages about 850lm for over 2h with 4500K Nichia 519As. I’d guess getting the same platform but with the new Lume1 driver would bump that result a bit higher still
I have a convoy S21E with the XHP50.3 HI in 4000K R9050. Reviewers have measured the same spec, but in 5000k, at ~700 lumens sustained lasting 2 hours and 45 mintues.
Anecdotally, I’d go for anything mentioned here besides the Firefly lights. In my experience they have the worst QC and the worst customer service. My first purchase from them was also my last. I believe buying from Firefly is like playing the lottery.
Recently I saw a post from another guy who bought two recent Firefly lights of the same model and one of them had a faulty switch. It would fail to register clicks for some percentage of the time. When he finally managed to get into contact with someone, “Ivy” told him that one of the switches regularly failing to register clicks is normal and it was not possible for Firefly to make all of them work the same.
Any brand can have a lemon, but good companies fix the issue, they don’t gaslight.
Actually, you have many options. Even though the search field is not ready yet in the database, I do have a Max lumen at 30 min mark in my spreadsheet for the most recent reviews. Normally, if the light can reach the >700 lumens after 30 min, you have good chances to reach it for 90 min or more with a 18650/21700 cell. I will try to paste the results here. My criterias are (1x18650 + 1x21700), >700 lumens after 30 min, form factor is limited to Angle light and Flashlights (no lantern, no headlamps, etc):
