Hi guys, I am looking for a high current cell and am currently trying to decide between Molicel INR21700-P45B and Samsung INR21700-50S. What are your opinions? I currently have a few Samsung INR21700-50E, but they can only do slightly under 10A.
Hi there, good question. I think you should either choose the P42A or P45B depending on your current requirements. Vapcell 21700s might be a good choice too
The P45B will vastly outperform the 50S in everything but low power applications that benefit from higher capacity. The only reason to use a 50S is for the slight advantage in runtime, but itâs only about 5% over the P45B and only for the latter 60% of the usable capacity before voltage cutoff. If your flashlights donât require more than 20 amps, the 50S is fine, but for more than that, the P45B is better (even a grade A P42A).
That is a very important aspect the OP overlooked. When calculating current at the cell, conversion factor of the driver has to be taken into account. 6V 8A boost gives you 48W output. With battery voltage at 4v to 3v it needs to supply up to 16A of current, plus conversation loss (about 5% for a good driver)
I have a few of them, so I measured the thickness for you and itâs ~ 2,52mm thick.
In regard to soldering Li-ion batteries:
I have limited experience with soldering onto Li-ion batteries, but I have soldered âblobsâ onto 3 flattop 18650âs and with some preperations and a very hot soldering iron/tip, it took me 1 to 2 seconds to solder a nice/round âblobâ onto a battery and directly afterwards I touched the battery to feel how much it had heated and there wasnât almost any extra heat in the battery, due to the very short contact with my soldering iron.
If you solder a copper pill onto the battery as HunterJackson suggested, you might need to heat it up a little longer/more, or maybe pre-heat the copper pill somewhat, because it might otherwise âsuck upâ part of the heat.
