we are here again, this time we bring the new family member, the LOOP GEAR SK05 Pro, attached a photo below, will keep updating about the project.
Update:
8/28:
We finally released 2 versions, the SK05Pro and SK05. Detailed information please refer to the Kickstarter Page.
SK05Pro Emitter:
Floodlight Emitter:Nichia 519A HIGH CRI (5000K) or SST20
Spotlight Emitter: SFT-25R
Waterproof:
IP68 Internal Waterproof Charing Port
SK05Pro Driver:
FET+Constant Current
SK05 Pro UI:
Dial Mode: LOCKOUT-FLOODLIGHT-SPOTLIGHT-SIDE LIGHT
From OFF(Unlock), press and hold to access momentary-on Turbo
SPOTLIGHT/FLOODLIGHT
1 click ---- on/off
2 clicks----Turbo
3 clicks ----(Strobe-SOS-Beacon)
From ON, Press and hold---- Low-Med-High
SIDELIGHT
1 click ---- on/off
2 clicks----(Whitelight----Constant on Colorlight----Breathing Colorlight----Dynamic Color Streamlight----Dynamic Color Droplight-----Dynamic Color Chasing light)
3 clicks ----(RED BLUE Flash)
From on, Press and hold---- White(Low[Similar to moonlight]-Med-High) ----Color(Red-Orange-Yellow-Green-IceBlue-Blue-Purple)----Chasing light Speed
Charging Indication: Dynamic Red Streamlight—>Dynamic Purple Streamlight—>Constant on Ice Blue
Discharging Indication:Dynamic Ice Blue Streamlight
What model of LEDs do you use in the side light? How many lumens does the white side light produce? Is it HIGH CRI? degrees Kelvin?
The flashlight should have more modes for each white light source, low/medium/high are few, at least it should have 5 modes and an extra 1 lumen mode with direct access from off with a long press.
