I installed session manger, its kinda confusing to me so far but i will try some of its features and figure out how they work, i do hope its as good as everyone says it is
Xmarks for an off site backup of ALL bookmarks…I must have over 2000 or more bookmarks and any time I can retrieve them or if I have to re-install on a new computer voila…syncs all my bookmarks to the new computer.
The combination of the session manager and tab mix plus add-ons to Firefox provides powerful control over tab management with no downside.
Once you install them, open the options windows and set them as you like. There is a setting for auto save. If Firefox crashes all of the tabs will automatically be available when it re-starts.
(Tab Mix Plus also provides the capability of Undo Close Tab when right clicking the tab display and you can control how many Tabs you want to be able to resurrect.)
At any time you can save your open session under a custom file name, and you can load any of your saved sessions to replace your current session… or add those tabs to your current session …there are many options available.
But here’s a little trick I use…
What I commonly do if I have hundreds of windows and tabs open in Firefox and it becomes slow to respond or act inconsistently or is unresponsive, is to use control-alt-delete to open Windows Task Manager to shut down Firefox in the Processes window.
This can be done at any time, and is essentially a “controlled crash” before Firefox crashes on it’s own, but either way, when you re-start Firefox, all of the tabs and windows will be recovered if you have “auto-save” turned on.
The advantage of crashing them and re-starting is that when they are restarted, only one tab from each window will be active. The others are only activated when you click on them. that reduces ram usage by 99%, and since Firefox doesn’t have to manage 500 tabs, it is faster and more stable.
Anyway, download these excellent add-ons and read the instructions…
Sounds like you could use bartab. Unloads tabs that haven’t been used within the time limit you’ve set. No need to crash / kill firefox to unload tabs from memory.
The session manager just worked fine in the weirdest crash i have seen in recent memory, except i lost a bunch of private tabs, is there a setting to save them as well?
Before anyone asks they were used to beat some paywalls
Bookmark them all, call the list private tabs or whatever, that way you can still find them and clean it up so its not cumbersome with 4 yrs old links. Or cant you bookmark them either? I dont private tab so have no idea if even possible.
