Thought i’d have a go (machine made)
plan is to build a dual emitter ,4 x 26350 cell light,
it will be a basic aluminum jobby with 2 xhp35’s
mtn max 4amp driver
reflectors 36 x28 http://www.kaidomain.com/p/S021791.36mm-D-x-28_6mm-H-SMO-Aluminum-Reflector-1-pc
26.7
a bit of prep cleaned the lathe.its a Chinese job I think they retail as grizzly in the states…
assembled the quality control committee
ordered the components from mtn
so I got a little time today and bought this little chunk of ally all I could get localy
seems I needed only half of it dwarfs the lathe even had to fit the reverse jaws
3.8.16
a bit of progress
been roughing the round into a square
so we now have a basically rectangle piece
have marked out the front for the reflector recesses
10/8/16
machined holes for reflectors and leds still have to recess front plate for glass lenses.
set up for machining pocket for driver and battery tube
I’m doing all this before the parts arrive I hope there advertised measurement’s are accurate
a bit more progress machined a thread in the rear
and added some grooves
I then refitted the 3 jaw made a arbor and spun the head the other way it was surprisingly true
continued adding grooves
18.8
got homefrom work and decided it was still a bit bulky so I gave it a trim
also reflectors arrived they are 36 x 28
more tomorrow
this old patcher I believe was my great grandfathers from the early 1900’s used to be a boot maker
its a singer 29k 13.
I also scrounged some leather from my dad,
and knocked up a sleeve for the handle
I may make a scabbard when I’m done out of the larger piece its about 4mm thick…
found some time today to start on the tail cap
my knurling is definitely not up to the standard of others i’m going to blame the $15 ebay tool…
ran a few grooves to match the head they are 6mm apart
bit of live action.
done 1 of the internal threads
the tail cap components
offered the tail cap up to the remaining member of the qc committee and she wasn’t interested at all
another botched up thread due to photobucket
finished product
