I got some of the cell top insulators used when wrapping a button cell. My magnets are the same size as the button would be, and the insulator is glued down (self adhesive) and thick enough to easily keep the magnet from slipping.
The Astrolux FT03 fits the size gap between the GT and Mini, though little different style. The FT03 head diam is ~70 mm, Mini ~50 mm, and GT at 135 mm. 92 mm would be a true mid range size though.
I don’t think I’ve ever seen that happen by any company and especially not by Lumintop.
I mean, they specifically designed that MCPCB for this light so that it could handle the heat. I don’t see them redesigning it or changing it for any reason.
I removed leds from an Imalent DX80 MCPCB. That was also huge. I needed to heat with hot air from bottom and with a big soldering iron around 150W next to each led before removing each.
Yeah, I tried my hot air gun at first as well but it just was not hacking it so I moved to the big guns. My full sized hot air gun from the garage could of done it but I did not have an outlet nearby so I just used the torch lol. I have used it in the past, got to be careful but it works good.
That “slice” was actually not intentional. It is one the issues that needs to be addressed in the production version.
Ah, okay. So there is precedence.
20mm to 16mm on a single xpl (maybe 25 watt) doesn’t seem so bad. Those are standard, off the shelf parts. I’m sure this giant GT4 mcpcb (handling around 250 watts) had to be custom ordered. I guess we’ll have to wait and see what happens. I seriously doubt they would downgrade it though, due to the extreme heat that needs to get transfered.
