ODL20C is a throw flashlight by utilizes a Cree XHP35 HI LED and adopt the aluminum flat and deep reflector, it emits a max 2,000 lumens output and creates an 860 meters long-range throwing distance by running on a 26650 cell. Five output levels plus Strobe, SOS and Beacon modes are more fit for various lighting demands. The USB Type-C charging enables a 2A current charging current and it takes only three hours to fully charged the battery. The humanized breath lamp allows easily locate the flashlight in the dark. Lock-out function, charging indicator, low battery reminder, tail standing ability and IP68 classification protection etc. makes ODL20C indispensable in your searching, rescuing, hiking activities and so on.
Features
- Utilizes Cree XHP 35 HI LED with a lifespan of 50,000 hours
- Powered by one 26650 rechargeable Li-ion battery
- High efficiency circuit with a max runtime up to 9 days
- Smooth and deep aluminous alloy reflector creates a max 860 meters beam distance
- 5 output levels plus Strobe, SOS and Beacon with a max output of 2000 lumens
- Humanized breathing light inside the switch, indicates the light location in the dark
- Durable USB Type-C charging with 2A max charging current, 3 hours to fully charged a 5000mAh Li-ion battery, fast and convenience
- Red and blue charging indicator visually shows the charging conditions
- Size: 151*59*35mm, Net weight: 300g (excluding battery)
- One side switch operation within one hand control
- Lock-out function prevents accidental activation
- Enhance cooling fins ensure a comfortable holding
- Low voltage indicator reminds to change or charge the battery in time
- Flat tail cap with tail standing ability to serve as a candle
- Toughened and ultra-clear glass lens with anti-reflective coating
- Made of aerospace-grade aluminum alloy, premium Type III hard-anodized anti-abrasive finish on the surface
- Waterproof to IPX-8 standard, 2 meters underwater (ensure the waterproof cover is in sealed condition)
- 5 years free repair, limited lifetime warranty
Familiar rabbit
Front, built-in red, blue light side switch
USB Type-C charging interface
LumibTop OD Series Brothers (ODF30)
Each of his duties
SDmini welcomes new members
All LuminTop made
Use a 26650 lithium battery, need to purchase
Say goodbye to the sun and prepare to test at night
ECO (moon)
Low
Medium
High
Turbo
Animation:
chart:
CREE XHP35 Hi has long shot ability
Smooth light cup
Put a piece of hard plastic on the outer layer of the plastic and the switch feels better
Charging instructions
Full charge indication
Low voltage indicator, animation:
Tail double spring
Positive copper plate and a black insulating gasket
Charging port waterproof cover
High quality
High quality
Deep ditch
Photo I
Photo II
Photo III
Photo IV
Photo V
Star Night Shot
Thanks for watching
