This is a short review for the Lumzoo GH10 angle light, which I purchased from BG the same day it was released and had an introductory price of $30. I’m a big fan of headlamps and when I saw this strangely shaped square head angle light being called the world’s shortest 18650 flashlight I didn’t hesitate to order. It also had very positive reviews on the Russian and Chinese forums, and I could confirm this the very first second I had in in my hands.
Packaging & contents:
No packaging at all, just a transparent ziploc bag with the light, a generic low quality headband and a spare o-ring, not even worth taking a picture, you can imagine it. For me it was fine because I hate fancy boxes, I like paying for the quality of the product not the packaging.
Build quality, size & ergonomics:
Let me start with the first interaction I had with it: it has been a couple years since the last time I experienced a tailcap screw this smoothly and that was on a zebralight H600. The threads on this lumzoo are perfectly machined and the oring has optimal pressure, making the twisting action very precise, smooth and with zero play. It is constructed from a single piece of aluminium and although looking square there isn’t any sharp corners or angles, I would say the machining is top notch and on pair with zebralights. Anodizing is well done and seems durable, it is less matte than armytek finish but not as shiny as skillhunt.
The size of this thing is simply mind blowing, barely longer than the 18650 it uses. It has excellent ergonomics and can be perfectly one hand operated in both handheld or headlamp form. When I first had it in my hands I could not believe this was a 18650 light, there are 16340 lights that that bigger and heavier than this. However for a light this compact there must be sacrifices, as it ONLY accepts single wrapped unprotected cells.
Look at how tiny it is compared to an unprotected 18650, a stripped down ZL H600, Skillhunt H02R, Armytek Wizard V3 and a Convoy S2+.
The battery compartment is so tight it barely accommodates a single wrapped cell.
It comes with a very sturdy deep pocket clip which allows it to sit fully inside your pocket. Due to the flat sides of the head the clip doesn’t spin but can be moved either side. This is one of the best clips I have tried.
Operation, UI & performance
The GH10 is operated via a single electronic switch on top and it is pretty amazing: unlike any other e-switch light I have, this switch is completely silent and requires minimal effort to operate, while still providing good feedback. Imagine the home button of a modern smartphone, but even softer and quieter. There is also a small red LED on the switch pcb to indicate when battery level is low by flashing when OFF. UI is as simple as it gets with 5 modes, click once to power ON/OFF and hold for modes. There is no strobe or aux modes of any kind.
Spec says 1,200 lumens on turbo but of course this is not true since it only draws 2.83A from a freshly charged cell. The driver is 7135 based with 8 chips and controlled by what appears to be an Attiny85. One amazing feature (or lack of) is that there is no step down, however this might be a con for some users. Because of the unibody construction the heat spreads evenly and I could still hold it comfortably after 3 minutes in turbo.
The performance of the GH10 perfectly matches the skillhunt H02R with only 3% variation in current draw and output measured via ceiling bounce. The Lumzoo however felt sightly brighter because of a more intense beam produced by the larger and deeper reflector. It performs excellently as far as stock lights goes.
The review would have ended here and I would have rated this light as excellent with 4.5 stars if everything continued to work fine…
However…
My happiness did not last long because just after a few days of moderate use, one night it suddenly started flickering like crazy while being OFF. It wasn’t the battery or bad contact, the driver just stopped working like it should. The 3 lower modes would flash in the same intensity no matter if on or off and the two higher modes would still work. See the video here: https://www.youtube.com/watch?v=7VWFqWiya5Q
After several emails with banggood, 2 videos and a bunch of pictures, their “professional guy” named Zoe was still asking if I used 2xCR123s or only 18650s, and if I have tried with a fully charged cell… I was patient enough to answer all of her questions and they finally agreed to sent me a new one free of charge. I said no need and opted for bangood credit to make things easier for them and also because I didn’t wanted 2 lumzoo GH10’s. Let’s see if they agree.
Fixing/Modding
Now that I don’t have to send this unit back to China I can proceed to fix and mod it:
By removing the 4x T5 screw on top the switch boot retaining plate goes off and the switch pcb is revealed, however not much to do here, the driver is glued and pressed from the other end.
Driver is out, 17mm, 4x7135 on each side, with 5 teflon wires out of it: ground, LED, LED-, switch, red LED. The ground contact is obtained by the back of the switch PCB which touches a ring of unanodized aluminum.
The front SS ring can be unscrewed by pressing it against a grippy surface like the back of the mouse pad. Once it is removed you can see the thin MCPCB secured by two screws with some low density thermal paste in between. The emitter shelf is about 2mm thick.
The stock MCPCB is copper and DTP. I decided to not replace it with a noctigon due to the thickness, instead I reflowed a XP-L HI V2 1A on it.
I have been keeping a very special driver for years waiting for the worthy host to use it on. This is with no doubt the perfect opportunity. Can you guess what driver is it? It’s quite obvious… Here I’m testing the driver and everything works fine, except the red warning LED of course. I always use a discharged cheap cell to bench test, less likely to burn anything in case of a short.
This driver is almost the same thickness of the stock one and the fitment was spot on. I potted the top side with some arctic epoxy. Because of the added front spring there is now ~1mm additional battery room, but still only accepting unprotected flat tops.
The HI emitter and this semi OP reflector is a perfect match, producing a very smooth beam with zero artifacts. The beamshot above is after the mod.
Modding difficulty: Medium
The hardest part was to fit all the wires in that tight space, I had to savage the 24AWG teflon wire from the old driver because 22awg silicone ones were too thick. If you only want a LED swap that’s an easy task. After the mod current draw dropped a little bit to 2.72A (the standard from the new driver), but now it has a much UI, better throw and a pure CW tint thanks to the XP-L HI V2 1A, The stock V6 1A was a bit too blue for my taste. I must say I’m very happy with the new internals, this will be my new EDC when I need to carry something compact.
Hope you enjoyed the read
