M44 with UV 365nm option
It would be great if a magnetic tail cap without the lanyard hole was also an option.
Also on my wish list: a 21700 tube.
Has the latest version of Anduril from TK with the improved stepdown?
Iā€™m more excited for the dual stage lockout momentary (allowing for moon mode while in lockout by holding, and ~60 lumens while in lockout by double tapping and holding).
Itā€™s still low enough that it wonā€™t cause any major problems (beside battery drain), itā€™s unlikely to activate in your pocket, and it is bright enough to be useful.
Fingers crossed. TK messaged Hank about it 2 weeks ago when Anduril launched on the original D4 (that one was using one build version too early for dual brightness lockout momentary).
So each light has all the aux colors?
Iā€™m thinking that ā€œmain LED tint x 7 aux color x 3 body colorsā€ would be way too many skuā€™s for anyone to stock.
Color me impressed. Iā€™d passed over the D4 beforeā€¦ now, subscribed. :+1:
How about a limited run with trit slots on the body and cap? :slight_smile:
Iā€™m guessing it means ā€œpick your aux LED colour when ordering, and then the settings for that one colour of aux LEDs are configurable on the lightā€, but I could be wrong.
edit: looks like I was wrong.
Each light has all the colors, you can choose any color by any time through ui.
Colour me pleasantly surprised. :slight_smile:
The only size difference is the tailcap, which is 3mm longer than then D4V1 tailcap, due to the magnet space.
Itā€™s with the latest anduril ui from TK.
Most likely, it should be compatiable, but we are not able to 100% sure since there are many different batches for the D4V1.
TK updates it so quickly that itā€™s hard to tell what the latest is :stuck_out_tongue:
Personally, Iā€™m looking for at least version 420 from 2019-05-22, but I think the improved stepdown was merged two or three versions after that (and to my knowledge, the latest is revision 428 on 2019-06-02).
edit: and here is a more readable changelog.
Awesome that V2 is coming! Canā€™t wait!!! :stuck_out_tongue:
I havenā€™t even received my latest D4 yet and this comes outā€¦
And 424 offers manual memory, which I find to be a huge improvement. Prior to 427, that has to be enabled at compile-time, but itā€™s the default now.
Excited to buyā€¦
Hank are you have any plan for 21700 in your product ?
Yes, sure, itā€™s under developing.
Looks greatā€¦ But I wish it had higher regulated current. I would rather have a 4mm longer light to accomodate 6 more AMC 7135 chips on the cellā€™s side of the driver, like the FW3A. 750+ lumens vs only 150 lumens regulated current.
Iā€™ll pass on this one.
Please let this one have a FET+6+1 driver or something in that range?
