Installed my 30mm driver in the L6 today with an XHP70.2 M4 30G 80+ CRI, and a lighted momentary switch. Loving narsil. I did have to file the driver edges slightly to get it to fit the driver pocket, but no big deal. 18ga wire. Haven’t measured current yet, but its super bright. The L6 reflector also blends the tint of these new emitters well, I dont have much color shift at all in the beam.
Hi Lexel, do you have any 30mm with narsil left?
I would like one for the L6 with LVP if possible, Thanks
I can build most of the driver, but I got no more FETs left
That’s fine. I could get the FET’s and solder them myself.
Would that still be OK? If not, no worries. :+1:
Btw where do you get your FET’s from?
i was thinking the same, so i swap out the 22awg wires for 16awg wires, to my surprise the current only increased by .5A and measures 11A at the TC.
That’s strange. Still, it’s plenty of light, though! Lol
I usually adjust my light to just below max to get better run time and less heat.
Another solution is to use a Dremel and remove some material on the reflectors base
And use some tape to protect the reflector from dust
or pieces of copper sheet or flattened strips of copper water line.
Or I could build the driver myself if you haven’t got the time, so long as you could flash the MCU?
NarsilM flashed for 1S or 2S without temperature calibration is not a problem
Is that built on a board or MCU on it’s own?
Either way is fine, if just MCU on it’s own I’d still need a 30mm board and then I could get the rest of the parts myself, unless you would supply the rest as a kit? I don’t mind either way so long as I’m not messing you about, it’s very decent of you to even offer this
so i decided to change out the 18awg for 16awg on my s70, took me a while to figure out how not to short thru the reflector. now it draws 12.5A - 12.9A at the TC with fresh Littokala. but the wried thing is i think the color is shifting from bluish on turbo to yellowish at lower setting. don’t think i recall this before.
If it’s starting to go bluish, then it’s getting too hot. Make sure the star surfaces are making good contact to the flashlight body and that you have good thermal grease on there. The reflector should be pressing the star down with some force.
On my L6 I was using copper shims under the star to adjust my reflector focus, but it wasn’t transferring the heat well enough and started to shift to blue. I removed all shims and it stopped doing that.
took apart the s70 again, and notice there is a dimple center to the led hot spot!!
don’t think i can do anything about this… spread around a little more thermal grease, screw the reflector as tight can i can, still i am getting that bluish shift in color
My drivers arrived today. Thank you Lexel!
What is this piece? Is it the edge of the copper folded over making a high spot or just thermal grease?
Does the color shift get Bluer and Bluer or does it stabilize? Because at high power these emitters do tend to get cooler in color but it’s a stable color.
i think it is thermal grease. not sure the stuff i have is any good, hy710.
the cooler color is stable, thanks for your advice
i can see the donut on turbo power, and this is with the OP relfector
