First off - No lumen/voltage/fancy charts, as I don’t have the gear for that. Also having a hard time getting my camera to do shots how I want them, but I’ve got the RAW images, so I can probably adjust exposure later (when Photoshop decides to work).
So:
I received my S11 from Convoy yesterday, and have finally had a chance to have a play with it.
It’s a 26650 body with an XHP50.2 using an OP reflector - I got 5000K because that’s my CCT of choice. It feels really good in the hand; a good weight, no sharp edges. At 100%, it does heat up very fast, but that’s to be expected.
I’ve since been reading that there’s a lot of green there, which I’ve experienced. This next image was taken around 3m away from my garage door at the 100% setting - still noticing a definitive green around the hotspot.
I’m feeling with a TIR that it’ll come nice, but it’s a 28.5mm (wide) by 20.5mm (high) reflector, so finding something to suit might be pretty difficult. For those interested, it’s a 7mm emitter opening.
The springs are bypassed, but the wire gauge seems to be fairly small, though this may be enough. Given that it’s a 6V emitter at 3A (w boost driver), a small cable might just do it.
The driver is a simple 4 modes plus hidden strobe; I feel this could really benefit from Biscotti or similar, with more options to choose from.
Overall, it’s fun so far, but…. really needs reverse clicky and Biscotti or similar. Simon has indicated that there’s not a direct reverse switch replacement, so I’m looking into the Omten 1288 (with slight modification for button height), and hoping for the best. I’ve been reading around that people have had it to 15A, so that gives me some confidence.
Some final shots for reading this far
