I bought an insect zapper machine about two years ago. It was rare occasion when I couldn't stand mosquito bites. Seems periodic flooding of the nearest swamp boost the population out of control. The insect killer worked too aggressive, it killed almost all night insects, not just mosquitoes, sometimes small gekkos too. Then I stopped using it because of several reasons:
- The 40watt UV tube light really hurt my eyes to a point I got a mild headache every time I worked near it. I consider it's also dangerous being exposed continuously for hours to any UV light.
- It's insanely too "UV" bright for night time use. The entire work shop was in purple theme, just like those 80's dance floor.
- The UV tube is somewhat fragile, I cracked two. And they're connected in series, I can't use just one (20 watt).
- The tube contains mercury which is poisonous and disposal of it's sharp fragments also not that easy
- Attracts not just mosquitoes but any insect with wings. Sometimes its overloaded by alates (flying male termites).
So, I plan to use less hurting mosquito attractant lights according to this paper (and also some other): http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=2002&context=usdaarsfacpub
Being a frugal and a budget community member, I decided to use my blue converted Nichia from my earlier post: https://budgetlightforum.com/t/-/44402 .
The ideal spectrum is 502nm (green) but I can't find the exact LED, yet I don't want to use my one and only green XPE. This BC 219C Nichia peak is in 438-439nm which is safer than UV and closer to 502nm. I don't know if this BC LED could catch mosquitoes better than UV, it's a scrap LED, it doesn't hurt my eyes as much as the UV, I can change it easily later with any LED.
Threw everything connected the bulbs
Replaced the lighting power supply with a waterproof MIC 300mA AC/DC LED driver. I just used 2mm thick, 25mm x 100mm aluminum plate as the heat sink, its only 5C warmer than the ambient temp.
Not much mosquitoes to kill tonight, we'll see if the blues catch better later. Although it's not hurting my eyes as much, the weird mood created is not much difference from the dizzy MC Hammer UV. It's feels more Vanilla Ice to me.
WARNING!!!: NEVER USE ANY KIND OF ELECTRONIC BUG ZAPPER LIKE THIS NEAR FLAMMABLE/FUME-ABLE PLACES LIKE AUTO GARAGE/WORKSHOP, KITCHEN, GAS STATION, LIBRARY, etc..
My personal experience when the machine overloaded with alates, it burned the alates and created an alarming fire sparks all night long.
- Clemence
