I received today my order from intl-outdoor and that means that I now have Qlite driver and XM-L2 T6 emitter :)
So I was wondering what shall I do now, should I try how would new XM-L2 work but the 16 mm
aluminium sinkpad with XM-L2 emitter is also a thinner than genuine sinkpad (not that big issue),
problem was that the reflector is too big for 16mm and has a groove that sits right on the contact
points for + and - pole so I would spend more time ensuring that it wouldn't come to a short circuit,
I would have to make some kind of spacer etc... too complicated.
While I was thinking, flashlight-oholic in me said: "Why don't you just swop the emitters?"
Interesting idea I thought, never done that before, I should probably take a note about emitters
polarity, but, before you know it, he (flashlight-oholic) grabbed high-tech-3-bucks butane torch from DX
and took off both emitters... Yeah, fun first - wory later :P
time to find a new home for those emitters ---> done & done :)
driver? --->check (yeah, I know, my soldering sucks. I was actually proud how nice it turned but then I
just wanted to "touch up" one spot -> messed everything)
of course I replaced those short&tiny wires with 20AWG-ones and squeezed big blob of thermal
paste under the emitter :)
finished product:
Looks nice, performs nice and it was fun to do it but no WOW effect
unfortunately. For testing I used TrustFire flames 2400mAh unprotected 18650 battery, pulls ~2,7A
on HIGH (tailcap), I had in mind to measure emitter amps but remembered that when my soldering
iron was already cold :/
All in all I will have to buy some high discharge batteries like this 30A Sony's and redo the testing
because 2.7A doesn't impress me anymore :P
As per beamshots, that will have to wait because my camera refused to work at night (something
to do with high power consumption of focusing mechanism and old/weak batterys)...
