No, all of the chips are in parallel, but if there is a slight short between the PWM and ground/output it could limit the PWM output enough to lose the low modes.
Hey guys, I'm a little behind (again) on orders, but Lisa says I've got to take a break tonight. I took the MPRE this morning and have been studying for that a lot this week, and I'm just plain exhausted. Will try and get some rest tonight and hit it hard again. Thanks for being patient.
Yes, I will be adding more tomorrow. I don't have a parts kit for wight's 7135+FET board available currently, but when I do you would have to tell me it is for his board otherwise the PWM output would be backwards (mine is switched due to the board layout).
I placed it into a tight brass pill, but may have bottomed it in the pill. I notice a cap soldered across the pins on the “brain” chip rises above the components. If this cap is shorted to ground (the pill), does that kill my modes? I only get max, no modes. I’m assuming if I space it out a bit (maybe use some kapton tape) I should get my modes back?
I soldered the off-time cap directly to the MCU pins because I knew that you needed it to be completely single-sided, and you selected guppydrv if I remember correctly. If it is grounded out, it won't change modes because the cap won't charge.
I ordered a fet +7135 driver, but the XPL V6 triples sold out before I got a chance to order them. I’ve just got to learn to order when things show up as in stock. V5 is almost as bright right?
One more question. I spaced stuff out and got the modes to work. How low is moonlight? I don’t find it that low. It’s pretty close to the 2% level by I assume that’s because I only have 1x 7135 chip?
It is because of the single chip. The minimum PWM level (moonlight level) I have with guppydrv is 5, which is what I flashed on there. I didn't have DrJones make any lower than that, because it is rare that anyone orders a driver with less than 3 chips. If I were building a custom program for that driver I would program 2 as the moonlight PWM with only a single chip.
